Help with PKALL wiring for custom install
So I doing a custom keyless entry/remote start and have everything figured out except for the bypass module wiring. Mainly is what to connect the Blue/White wire that is suppose to be connected to the Remote-Starter/Alarm and (-) while running. Not sure what it needs to be connected to since I will not have a traditional remote starter. Anybody that can help would be appreciated. Thanks
That Blue/White wire should be hooked up to the alarm/remote starters Running (-) wire. What it does is when you go to use the system to start the car, it sends a signal through that wire to the bypass telling it to arm the RF bypass for the key to the cars ECU thinks the key is in the ignition and can start. I was spinning my head trying to figure this out myself during my install, once I hooked this wire up it started like a beaut!
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Scionxa180
Feb 17, 2015 05:35 PM
CONCRETETC
Feb 9, 2015 08:05 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
