HELP, PLEASE!!! Car Alarm
Old Apr 2, 2008 | 12:47 PM
alec's Avatar
Default HELP, PLEASE!!! Car Alarm
I installed an alarm and everything worked fine, EXCEPT my car won't start. Removed the alarm and car still didn't start. Any suggestions would be greatly appreciated.
Old Apr 2, 2008 | 03:19 PM
jurassic1's Avatar
Check the underhood fuse box and the fuse box inside as well. What kind of alarm did you put? Does it have remote start? You did disconnect the battery before the install right?
Old Apr 2, 2008 | 03:32 PM
ppiech2's Avatar
1.check all the fuses.
2. Make sure everything is grounded properly.
3. Did the alarm have an engine cut-off? If it did, check all the connections to the ignition and/or starter. Get a simple volt-meter and check where in the circuit you are loosing power.
Old Apr 2, 2008 | 03:59 PM
alec's Avatar
Just a generic alarm. Everything is working, apparently not everything, all the modules are working fine. It's just my car won't start. It's not remote start. Fuses everything are ok. Are their any kind of alarm reset?
Old Apr 2, 2008 | 05:05 PM
jurassic1's Avatar
reset? other that disconnecting and reconnecting the Neg. pole of the batt (say for 2-3mins), can't think of anything else...what's the brand of your alarm? Maybe it has a website/Tech section....
Old Apr 2, 2008 | 05:26 PM
alec's Avatar
Brand name is Asianwolf, apparently they are closed for the week to go to some convention in vegas, and their website went under construction. Can't get help from them til the 7th of april.
IrjI619
Jan 28, 2015 05:21 AM
xdejablu3x
Regional - Mid South
Dec 29, 2014 02:15 AM
BV19869
Dec 11, 2014 06:05 PM
ScionizeD
Dec 4, 2003 10:33 PM
tC_Normo
Oct 22, 2003 07:20 PM
