Help Please..Front Right Speakers Arent Working
So yea my front Right Speakers are not working and I dont know why..my rear, stock sub, and front right speakers are working but nothing from the left. No idea why they are not working since I dont blast my music..Im pretty sure I didnt blow em. Any suggestions would be gladly appreciated..I feel so sad right now.
Oh yea I have an Pioneer Avic D3 head unit. I took off my center console and check if all the wires were connected..everything seemed ok so I dont think it has anything to do with that. I did install VRD fogs a couple of weeks ago but I doubt any of the wires near the mirror controller near the interior fuse box makes a difference. Do you think if I get it checked out at the dealership, that it would be covered under my warranty?
I'm corn-fused.
Check your left (I mean right?) speaker wire connections again. Sounds like something is loose.
I'm corn-fused.
yea drilled the holes for the brackets, did some bypass and so on but mainly the crips and other stuff was done by a friend of mine. I had the D3 headunit for 4 or more months already. I cant seem to figure out what the problem is. I spent an hour taking out the center console checking to see if all the wires are connected..eh cant seem to find out what the problem is. I just know that I recently installed VRD fogs, dont know if that comes into play.
take a digital volt meter, go behind your radio. Set your meter to ohms and put the probes on white and white/black. Should read around 4 ohms. Or set it to continuity and place the negative probe on a good ground and take the other and probe those white and white/black wires. If it beeps you are grounding your speaker wire and it wont work.
clickclickw00t
Feb 18, 2015 08:57 PM
