Help please, problem with Alpine's :-(
Old Jan 15, 2008 | 03:33 AM
trialsindude's Avatar
Strictly Scionized
I dont know what happen, it happen during the summer, yep my Knu distro block melted, and my OEM ground wire from battery to chassis burnt up.
However, in your case, I would tighten those nuts down or re-strip pull back all the wires as far as you can so that when you tighten the nut it will pull the wires even more.
Get solid connections and see if your amps will turn off this time.
Old Jan 15, 2008 | 03:40 AM
kidwolf908's Avatar
Yea that's my whole day tomorrow... Just need my crescent wrenches from my mom's car
I hate that it was all perfect and then I put in this and it all goes to hell :-\ But hopefully I can get it straightened out on my own! Trials do you ever do the Friday night drives?
Old Jan 15, 2008 | 03:50 AM
Strictly Scionized
Drives where?
So yeah my Knu block ended up getting loose on its own, then when ever I would turn my stereo up the amp will cut out. No protection light or anything but power light is still on...it was strange. If I turn the car off then back on the amp will come back to life.
But lets hope that it is a loose connection that is your problem because that would be an easy fix.
Old Jan 15, 2008 | 03:55 AM
kidwolf908's Avatar
Drives where?
Yea I hope so. And the drives that people in our area go on... Look in the Mid Atlantic regional forum, apparently there is a regular group of people that all get together and hang out friday nights and show off cars and chill. Sounds fun
Old Jan 15, 2008 | 04:08 AM
Strictly Scionized
If you are talking about this one:
https://www.scionlife.com/forums/vie...asc&&start=860
I'm not driving that far to hang out with 3 people and then spend more money! Gas is expensive!
Old Jan 15, 2008 | 04:16 AM
kidwolf908's Avatar
Haha, it's only 3 people? Thought it seemed like more :p
Oh well, we'll do a drive of our own, down white marsh blvd and back lol
Old Jan 15, 2008 | 03:46 PM
travis1041's Avatar
hey if i was you i would get another battery and hook the amp up to it with shorter wires make sure they are at least 2-4 gage wire then crank it up if it still does it you should be able to rule out the wires
Old Jan 15, 2008 | 06:09 PM
kidwolf908's Avatar
AHA! The damn ANL fuse in the fuse holder was loose! Right where it was sparking last night. I popped the top off and cranked it down hard as I could, sat there and listened to the system at higher volumes than it died on before and no issues... Wiggling the wires doesn't cause it to cut out anymore, and from what I could tell, no sparks! :D
I still need to get more allen wrenches from my dad to tighten up everything else that I thought was already tight, but what the hell, might as well be sure. But I just wanted to let you guys know!
And @tcguy: I LOVE the sub! It's soooo perfect for the music I listen to. However, on some songs that just must be bass heavy, it seems to overpower my comps...makes me wish I could turn the gain up just a tad on the front stage, but at all other times it's perfect. Right now I have it crossed at 55/63, sub/comps. Do you think there's anything I should tweak to make it blend just a little better with my fronts?
Thanks everyone!!!
Old Jan 15, 2008 | 06:30 PM
Strictly Scionized
there you go! glad it worked out in the end.
Old Jan 15, 2008 | 08:10 PM
kidwolf908's Avatar
Yea I know...and after driving with it, I think I need to turn the comps up some more. I want to take the overall volume up as well so I can get maximum signal-to-noise, but I just feel that the sub needs to be toned down just a tad for certain types of music.
Again, thanks everyone! And lemme know if there's any suggestions you have to make it sound better
Old Jan 15, 2008 | 10:24 PM
Tcguy85's Avatar
try the sub at 50hz/12db and the comps at 63hz/12db. if you have even steeper slopes(i'm pretty sure you don't though) then try them. can you adjust the sub volume from the head unit? the pioneer should let you adjust the sub volume right from there. i change mine a bit from some music to others.
he sub sounds great doesn't it? once you play it for a few days and it breaks in and loosens up you'll like it even more. the output increased a lot and it dropped lower after a couple days. it can really slam you in the back right?
have any pics for us? i really wanna see the box!
Old Jan 15, 2008 | 10:26 PM
kidwolf908's Avatar
So, today I get my sub working and all is great right? So I go to get dinner for my family from work and while sitting at a red light, some _______ in a Jeep HITS ME! It wasn't a hard hit, but he just let go of the brake and hit me right at the stop light! My bumper has a little dent in it from his and some scuffs, not enough to worry about, but to add to it, the dude just drove off even when I pulled over! I got his license plate #, but I probly won't call the police since it's not worth the hassle...
Nonetheless, who does that when they know they hit you? I looked in the rearview and saw his face when he did it, "Oh ____" was written on his forehead lol
Old Jan 15, 2008 | 10:30 PM
kidwolf908's Avatar
Yea it sounds awesome and yes it reallllly can thump when you want it to! lol... And yes I have a controller on the HU that'll let me turn the sub down 1-15 dB's, I just wanted to get it mostly perfect through the amps and then fine tune with the HU... too much processing can kill SQ. But some guy on DIYMA also suggested reversing the polarity of the sub via my HU's "reverse" sub feature, said it can help make the sub and comps blend more...
You heard of that before?
And yea I'll get pix tomorrow, it's too dark right now and I was too busy enjoying it today :D
Old Jan 15, 2008 | 10:35 PM
Tcguy85's Avatar
yes! def try reversing the polarity, do it from the head unit though so you can hear the change as your making it. just keep going back and forth while playing music and see which way you like it better. one way should make it blend a lot better. at least in my case it did.
what it will do is make the comps and sub better timed and more in phase with each other on one setting. and since the RSD comps actually make pretty damn good mid-bass you should hear it either blend or fight with them. def try it. i know in my case i hear a huge change when i go back and forth.
i'm really glad you like the sub! :-) keep playing it and it will break in and loosen up and sound even better after a few days.
Old Jan 15, 2008 | 10:38 PM
kidwolf908's Avatar
Yea I'm gonna go check it out now
It's gonna take a while to get it all perfect, I know, but I just can't wait! lol...
How do I determine what the dB/octave slope is on my crossovers?
Old Jan 15, 2008 | 10:40 PM
Tcguy85's Avatar
are you using the crossovers on the head unit or the amps?
if it's on the head unit it should say in the menu. if it's the amps just check the specs on the amps to see.
take a picture of the box and post it!!! use the flash if you have to, i wanna see it!!! lol
Old Jan 15, 2008 | 10:57 PM
kidwolf908's Avatar
I'm using the crosses on the amps, so I'll look it up. And fineeeee alright. I'll go take one and get it for you lol. I'm gonna take pics of EVERYTHING when I can get my car down to my heated garage at my other home :D
Old Jan 15, 2008 | 11:02 PM
kidwolf908's Avatar
Interesting, my PDX2.150 running the comps is -12dB/o but the 1.600 is -24dB/o...
What does that mean for me? lol
That I can cross the sub higher and it'll come up closer to the range on the comps without interfering as much as if it were -12?
I'm a noob lol
And apparently, my HU can adjust the db/o on the HPF from either 0,-6, or -12. But the LPF on the HU can be either -6, -12, or -18 db/o.
I wonder which I should trust/use, the amps or the HU :-\
Old Jan 16, 2008 | 12:17 AM
kidwolf908's Avatar
Well I'm not too sure the "reverse" thing on my HU is either a) not enough reverse or b) just not that effective to my ears. It did change, but just a slight bit. Sometimes more noticeable than others, but not better or worse than normal by much. I think I really need to tweak the crossovers a little more, I have the sub at 55 and the comps at 63 and I kinda feel like it's peaking in that range. If I set the LPF on my HU to 50, it's MUCH better, but then lacking a little bit in bass, so perhaps dropping it to 51 or 52 and tweaking my EQ and gains could help me out :-)
Old Jan 16, 2008 | 01:24 AM
Tcguy85's Avatar
can you turn the crossovers on both amps completely off and just use the head unit's crossovers?
if so i would try them both at 12db, with the comps at 63 and the sub at 50. i have the same comps and sub as you in a box with the same tuning as you. that is what worked best for me after playing with it over and over again.
but now that i can use 24db slopes which are twice as steep i have both crossed at 50hz with the 24db slopes.
but in your case try then both at 12db 63/50
