HID/ Projector Retrofit Question!
Old Sep 1, 2011 | 10:41 PM
chicotunner07's Avatar
you need to spend some time on hidplanet.com, you can learn all you need about lense swaps and custom shields!
Old Sep 2, 2011 | 12:24 AM
aksc's Avatar
Yep, I agree!
Thanks for you help man! Really appreciated...
Old Sep 2, 2011 | 12:28 AM
aksc's Avatar
Originally Posted by fongyz
I retrofitted bmw e46 projectors with 3" lenses into my high beam area, keeping the 08 oems in the low-beams. they aren't too bad, but stick with FX-R or TSX projectors and you'd get a more sharper cutoff and more width.
@ AKSC - I haven't measured the TC lenses but from a quick , Low Beam Projector=2 5/8" i.d. - the shield is a fully integrated with the mounting bracket, so unless u wanna cut and stuff.. modding it i just put a few small washers to space the shield further away from the bowl to get that blue cut-off (and also a slight curvy bend of the shield INWARD towards the bowl..)
TC projectors are designed well, u can literally "pop" the lenses off and swap em out! You may want to change the bowl too since it does have a foreground scatter / limiter.
In regards to wiring, PNP HID kits for ~ $50 work fine WITHOUT connecting to battery, u just connect it to the stock harnesses to get power. The wires are thick enough plus u get stock fuses and relays to do the work for you. Never have I connected it directly to battery for power, only my halogen fogs are wired that way. ;)
Okay man, sounds good. Got another good deal on a HID Kit. $35 for a 55W DDM Kit w/ 6k bulbs.
But just a quick question, do you know what lens size will fit the OEM Projectors? Sorry for all the Nooby-A$$ questions. I think I have ranked up and now it's time to start asking away on HID Planet.
Thank You for your help! It's very much appreciated!
Old Sep 6, 2011 | 05:20 PM
fongyz's Avatar
I'm not sure on the size of the lens, I didn't measure them prior to installing them back into my headlights, I'd guess they are 2.25" ? I'm sure you can google "camry gen 6 projectors dimension lens" or of some sort and get results from other forums.
bootlgr
Jan 26, 2016 01:22 AM
yoson13
Scion xA Aero & Exterior
13
Aug 29, 2015 11:12 PM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
