HID w/o relay harness vs. w/ relay harness
Old Mar 11, 2012 | 07:06 PM
Tshock's Avatar
Originally Posted by TheMuffinMan00
Basically it just creates a good connection.
If you have two pieces of metal that is constatly making a connection then losing you have arcing. This creates heat and will melt the factory plug and wiring. In An HID case this causes flickering and if the connections is not good when you go to turn them on and you have a poor connection for the first 2 seconds the ballast quits trying to turn the bulb on so it won't try again even if power is sent to the ballast as you are driving down the road.
the dielectric grease is actually conductive so when you put it in the plug fittings it "fills in the gap" so the terminals are constantly touching and getting the power they need and doesn't let them arc and create heat.
The terminals are isolated in the plugs right? Otherwise smearing it inside the entire plug would create a commonality between both terminals thus arcing the two?
Old Mar 14, 2012 | 02:24 AM
TheMuffinMan00's Avatar
You would have to like fill the whole plug up in order for that to happne. I just put a pretty good dab on each terminal then plugged them together.
Old Mar 14, 2012 | 02:48 PM
Tshock's Avatar
I sure am glad I asked. After your first mentioned it I envisioned the grease oozing out of the harness as I plugged it back together lol. Ill use it sparingly.
Old Jun 5, 2012 | 01:44 AM
profipix's Avatar
Guys,
I installed the relay kit and now my car wont start. Any ideas?
SloTC1
Aug 16, 2018 02:45 PM
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
spharr62
Sep 20, 2015 01:44 AM
SJMiller
Sep 12, 2015 06:33 PM
scionsux
Sep 2, 2015 05:30 AM
