how can i run this? [help]
Run 1 large power wire from the battery to a distribution block mounted near your amps, then smaller wire from the dist. block to each amp. Here's a link to an inexpensive, yet good quality distribution block;
http://www.parts-express.com/pe/show...number=265-800
idk it seems like it would work fine each channel is 175 rms and each VC is 150
The amp bridged is going to be putting out 120W RMS to a voice coil that is 150W. Each channel is putting out 60W RMS @ 4ohms and 90 @ 2 ohms.
I have the same amp, and it overheated a few times pushing a subwoofer rated at 200W RMS at 4ohms, and 2 speakers up front.
As for the power of those amps, what TheQuietThings stated is correct, you're apparently getting a bit confused due to both RMS vs "max" output ratings, and the impedance the subs will present to the amps. You can use those amps and they'll drive the subs ok, but you'll need the gains set correctly to avoid distortion and won't be getting all the output the subs are capable of. It'll be ok, but it's less than optimal, you'd be better off with amps that could run bridged 2-Ohm loads, or a single more powerful amp, whether it's a 2-ch or mono model.
Don't pay attention to "max" ratings, look for "RMS", and realize that with most amps, the 4-Ohm output is often only 50-70% of the 2-Ohm RMS spec. Also many amps (like yours) can only handle a 4-Ohm bridged load, they'll have problems if your try to run them 2-Ohm bridged, which is what you'd get if you parallel wire the 4-Ohm VCs on one of your subs.
r3aper503
May 15, 2015 06:31 PM
DDonovan
Regional - Canada
Mar 23, 2015 08:51 PM
cid_mcdp
Jan 5, 2015 02:45 PM
