How hard is it to install an alarm in the tC?
Old Nov 25, 2007 | 08:40 PM
blazeplacid's Avatar
Default How hard is it to install an alarm in the tC?
Well I have almost all the stuff i've ever dreamed of audio wise.
I dont want anyone to mess with the car so im ready to get an alarm.
In general how hard is an alarm install?
Im pretty good at finding wires and wiring in general.
im not a master tech but ive done all of my own installs but have never doen an alarm.
I have done nav units,xm/siris,subs and amps, the usual stuff.
I was looking at this alarm http://www.circuitcity.com/ccd/Expan...=9#custRatings
would that work with our cars? I've heard some cars and alarms dont mix.
If thats not a good alarm what do you guys recomend? Or does someone have an alarm they have in thier car? im looking for remote start and a way to keep the keyless entry. I dont really care to much about the trunk popper or anything like that.
Of course I want an alarm with a siren.
Also where did you mount your alarm brain box? I know thieves know where these are located most of the time so where is a good place to hide the box?
thanks
Old Nov 25, 2007 | 08:42 PM
forgot to mention i would like a pager and a long range...which i dont think that unit does
Old Nov 25, 2007 | 08:56 PM
BLKLIMETC's Avatar
The new viper lcd pager has sst 2-way pager which provides quite a bit better range than the older version...except still has issues in certain building and parking garages. They arent too hard to install just depends on your experiance of course..mine was quite a bit easier to install considering ive done my cars with the dash completely out to a bare firewall where all the hard ware and back up batteries are located
Old Nov 26, 2007 | 01:51 PM
jeremyc's Avatar
Well, the link you provided for the python 1400 will work in your car as long as you are looking for remotestart and keyless entry only. That unit is not an alarm. You want a unit like this http://www.circuitcity.com/ccd/Searc...rchSection=All If you are planning on buying a unit like this at a store such as circuit city or best buy, let them install it. The installation price is included in the price listed. You have to keep in mind that we have a transponder in our keys that will require extra parts and labor to bypass. If you dont bypass this the car will not start no matter what you try. Installation of a remote start is not something i suggest for a novice. You will have to search for many wires and unless you have some sort of tech program you will never find all the wires needed. Like the mulitple wires needed to run the locks. the door trigger, the park lights and the Tachometer wire... just to name a few
Old Nov 26, 2007 | 02:35 PM
thanks for the reply
I know how to find the tach wire and what not but i dont wanna spend an entire day fiinding wires.
I called the CC near me and they said come in and get an estimate, which I under stand.
Ill update soon
Old Nov 26, 2007 | 04:36 PM
karatekidd's Avatar
Ill update soon
Install for any alarm by them should not be more than $150-$200....I got an alarm installed by CC in my Nissan truck...which had manual door locks and windows...
$150+tax and labor....
You really shouldn't spend more than $200 for everything...
Old Nov 26, 2007 | 09:19 PM
ichibansf's Avatar
A Clifford 50.5 system costs about $300 w/o installation. Local prices here in San Francisco run about $500 installed, but I think our labor is higher than most other places. Install shops will not officially install remote start on manual transmissions due to liability reasons.
Old Nov 26, 2007 | 10:49 PM
karatekidd's Avatar
i've heard that too....in reference to the liability thing....
Old Nov 27, 2007 | 06:39 PM
mattieg's Avatar
I do this stuff for a living. If your going to do it take your time. You can only take off the steering column to access the ignition harness. And if you want to do this on a manual transmission you need to get yourself a 689M module for it. Here is the wires you need...
Security
WIRE COLOR POLARITY LOCATION
Battery RED (+) IGNITION HARNESS
Ignition 1 BLUE (+) IGNITION HARNESS
Starter 1 BLACK (+) IGNITION HARNESS
All Door Trigger BLUE (-) LEFT SIDE OF FUSE BOX
Domelight Super USE ALL DOOR TRIGGER
LF Latch ORANGE (-) TOP OF FUSE BOX
DIODE ISOLATE THE DOOR TRIGGERS
RF Latch BLUE (-) TOP OF FUSE BOX
LR Latch RED/BLUE (-) AT REAR LEFT DOOR PIN SWITCH
RR Latch RED/BLUE (-) AT REAR RIGHT DOOR PIN SWITCH
Trunk Trigger PURPLE (-) TOP OF FUSE BOX
Alarm Disarm DISARMS WITH UNLOCK
FOR DISARM WITHOUT UNLOCK, USE KEYSENSE
Alarm Arm ARMS WITH LOCK
Parking Lights BROWN (+) TOP OF FUSE BOX
Low Crr Pk Lights BROWN (-) HEADLIGHT SWITCH
Convenience
Headlights-Lo PURPLE (-) HEADLIGHT SWITCH
All Hazrd Lights ORANGE (-) HAZARD SWITCH
Wipers-Lo GREEN (+) STEERING COLUMN
Wipers-Hi WHITE (+) STEERING COLUMN
Parking Brake BLACK (-) PARKING BRAKE SWITCH
Trnk Release ORANGE (-) 12 PIN CONNECTOR DRIVER KICK, PIN #12
Remote Start
Ignition 2 YELLOW (+) IGNITION HARNESS
Accessory 1 GRAY (+) IGNITION HARNESS
Starter 2 GREEN (+) IGNITION HARNESS
Anti-Theft Type IMMOBILIZER
Anti-Theft Descript TRANSPONDER
Key Sense BLACK (-) IGNITION HARNESS
THIS WILL ALSO DISARM FACTORY SECURITY
Tachometer BLACK (AC) DATA CONNECTOR, UNDER DASH, PIN #9
Speed Sense PURPLE
Low Crr. Pk Lights BROWN (-) HEADLIGHT SWITCH
Brake Lights BLUE (+) BRAKE SWITCH OR DRIVER KICK
Reverse Lights PINK (+) TOP OF FUSE BOX, PIN #2 IN A 14 PIN CONNECTOR
Horn WHITE (-) STEERING COLUMN
Modules
WIRE LOCATION
Module 1 ECM IS LOCATED BEHIND THE GLOVE BOX
Doorlocks/Windows
Power Unlock PURPLE (-) 20 PIN CONNECTOR DRIVER KICK, PIN #14
REQUIRES A DOUBLE PULSE TO UNLOCK
PowerLock GREEN (-) 20 PIN CONNECTOR DRIVER KICK, PIN #15
DOORS MUST BE CLOSED IN ORDER TO TEST
Driver Mtr Unlock PINK (REV) 7 PIN CONNECTOR DRIVER KICK, PIN #5
Driver Mtr Lock BLUE (REV) 7 PIN CONNECTOR DRIVER KICK, PIN #6
Pas Mtr Unlock WHITE (REV) AT INTEGRATION RELAY DRIVERS SIDE DASH
LF Window Up YELLOW (REV) DRIVER DOOR WINDOW SWITCH
LF Window Dn PINK (REV) DRIVER DOOR WINDOW SWITCH
RF Window Up YELLOW (REV) DRIVER DOOR WINDOW SWITCH
RF Window Dn GREEN (REV) DRIVER DOOR WINDOW SWITCH
Old Nov 27, 2007 | 06:40 PM
mattieg's Avatar
Also since you need to diode isolate the doors. Pick yourself up 3 amp diodes. And go to the12volt.com to learn more about wiring it.
Old Dec 28, 2007 | 12:55 AM
x219c's Avatar
I've installed remote starters on 3 vehicles. The only one I've had a problem with is a Ford Focus. Can't find any usable tach wires... But, everything else is easy as pie. In fact, the camry I put it in, you just hook up 2 wires to the door lock control wires under the passenger footspace, and thats done... then the remote start was easy as well... no tach wire required. Everything took under an hour on that one.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
xdejablu3x
Regional - Mid South
Dec 29, 2014 02:15 AM
racingtoys
Dec 4, 2003 10:34 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
