Ignition Ring Light..
Hi my Scion friends. I'm new here and I was hoping that if I joined this group the members would have some helpful answers to some of my questions. For now I will just ask one.
Does anyone know if it possible to change the color of your ignition ring light. If so how would I go about it?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Oct 14, 2019 at 09:20 PM. Reason: Moved to Correct Forum by Administrator
If you pull the plastics off around the surrounding area, that is usually like a little #74 bulb that can be changed to whatever you want. The ring itself might be a tinted plastic that is a certain color tho, in which case changing the bulb might not do much if the light is refracted thru a colored lens. But if the ring is clear it should pickup whatever color the bulb is. I haven't been in a tC1 in forever, so I forget what color the ring is.
SpdLmtNA
Oct 20, 2005 02:33 PM
TREX212426
19
Oct 2, 2004 01:45 AM
TREX212426
Sep 29, 2004 09:52 PM
