Installing LOC help
Old Dec 14, 2008 | 09:34 PM
dye4metal's Avatar
Default Installing LOC help
ill be installing a system into a 07 scion tc this week for a friend. ive done about 8 installs now and im familiar with everything i just got a couple questions about the wiring in these cars.
Im gonna be using a PAC-SNI35 loc converter http://www.mobilcaraudio.com/catalog...160/983991.htm
which speaker are most people using in these cars?
also on the remote wire, what are you guys using also?
Old Dec 14, 2008 | 09:57 PM
ekgaudio's Avatar
Tell them to buy a new head unit
Old Dec 15, 2008 | 03:40 AM
dye4metal's Avatar
no more money
ive tried convincing them.
Old Dec 15, 2008 | 04:49 AM
a_german_named_hans's Avatar
stock HU is good enough for my use. I run a loc. I run it off the rear speakers. don't remember the wire colors. Tech section should list them tho.
Old Dec 15, 2008 | 04:50 AM
Sciontistical_One's Avatar
I've hooked up the LOC into the rear speaker outputs and ran it to the sub's amp since I don't use rear speakers in my car. The front is more than enough for imaging. Then I've tapped into the ignition lead for the remote for a switched 12 volt source. If you look around, you can find a wiring schematic on a PDF file in this forum.
Old Dec 15, 2008 | 04:52 AM
^^ are you supposed to disconnect the rear speakers if u run a loc on them? I didn't disconnect the rear speakers. I tapped the LOC in right at the head unit.
Old Dec 15, 2008 | 05:03 AM
yeah, I disconnected the rears since I don't use them in my system (for music)... I actually use my rear speakers for my bluetooth... the sound from my phone comes thru the rear speakers, while a mic next to my shifter picks up my voice...
Old Dec 15, 2008 | 11:13 AM
dye4metal's Avatar
so you shouldnt tap into the rear speakers when you have them? that doesnt sound right...?
Old Dec 15, 2008 | 06:15 PM
SquallLHeart's Avatar
tapping is fine... that's where the factory subs get their signals..
Old Dec 15, 2008 | 10:32 PM
rcf22's Avatar
It's ok to tap into speaker wires while their in use, but he's just saying he didn't at the time.
Also, I'm pretty the factory sub receives its signal from the front speakers.
Old Dec 16, 2008 | 02:56 AM
dye4metal's Avatar
so for the remote i should just tap into the ign.?
Old Dec 16, 2008 | 04:26 PM
Yeah, I didn't mean to say that disconnecting the rear speakers was required... it's just my preference... and I also have them used separately for my bluetooth...
Unfortunately, I never had the factory sub, so I can't contribute an educated answer to that question...
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
Docsnuff
9
Nov 23, 2003 09:50 PM
