IS300 Foglamps
Old Aug 12, 2005 | 05:13 PM
BlkSandPrlTurbotC's Avatar
Default IS300 Foglamps
Ok, so how would you run the wiring? I know you can do a switch on the inside
but anyone who has this process done, do you have a write up?
Old Aug 12, 2005 | 05:24 PM
Brent_23M's Avatar
Ask "Blue tC", her name is desiree, she installed them and will be able to help you. Search the topic "IS300 fog lights" to try and find her post.
Old Aug 12, 2005 | 05:26 PM
thanks tavis!
Old Aug 12, 2005 | 08:17 PM
Brent_23M's Avatar
Im not Tavis.... he does work here though, I'm Brent
Old Aug 12, 2005 | 09:42 PM
oh. lol. sorry bout that. I saw scion of waldorf and just assumed.
glad ur on the site!
Old Aug 12, 2005 | 11:16 PM
Jimmy's Avatar
starting on the passenger side, run both positive and negative wires. run your wires where you'd like, i put mine in front of my radiator.
ground your negative. do the same for your other foglight. run your positive wire through your firewall...to your switch... to fuse box by your pedals.
crimp whatever wire you were running to a small wire, 16 gauge. keep the length short as possible and fuse it to "ACC 24"
the reason why i fused it to acc 24 was because you can turn on the fogs without the headlights on
i might have missed something. but thats how i did mine
Old Aug 12, 2005 | 11:56 PM
Brent_23M's Avatar
Did you search tech? Also, do you already have the fogs?-how much did you pay for them and where from?
Old Aug 13, 2005 | 03:10 AM
Jimmy's Avatar
if you are talkin to me. then no i didnt do a search, yes i have the fogs. i got them from the is300 forums
Old Aug 13, 2005 | 05:04 AM
ProjectD's Avatar
Here you go. This is the same diagram I gave Blue tC.
Old Aug 13, 2005 | 12:08 PM
Jimmy's Avatar
oh yea, i knew i forgot about the fuseholder
Old Aug 13, 2005 | 03:09 PM
maximus96's Avatar
when you tap into the fuse box, make sure you tap into a fuse that turns off when the engine is off and not a constant 12v.
Old Aug 15, 2005 | 07:56 PM
Copy that. Thanks guys
Old Aug 16, 2005 | 01:39 AM
DTRUONG_112's Avatar
how much do they go for?
Old Aug 16, 2005 | 05:36 PM
bOhEmIo82's Avatar
^ what he said.
Old Aug 16, 2005 | 07:02 PM
Jimmy's Avatar
fogs average about 100-150
rAndal
21
May 10, 2011 05:57 PM
RobbyxA
Jun 4, 2005 10:12 PM
dmikon
May 13, 2005 05:28 PM
clipper453
Sep 25, 2004 08:20 AM
djct_watt
Sep 1, 2004 12:46 AM
