LED help
pop off the christmas trees thats holding the engine cover on (the cloth thing on the under side of the hood)
the stock ones u squueze and they should pop out from the front of the hood.
insert the new ones screw them in with the bolts that they provide.
run the wires through the hood if you want so their hidden.
run each down the fenders of the car and your yellow running lights are the ones to tap into. they should be right there on top facing out. shave off a little of the rubber coating with a kknife or something be careful! soder the wire that came with the nozzle and the exposed wire. or if u dont want to soder just connect the two wires use a splicer and clamp it down. wrap it up with some electral tape. zip tip any exposed wire so u cant see any and put the engine cover thing back on the hood. and there ya go.
SJMiller
09-12-2015 06:33 PM
