my CD1 Pro MH
Old Mar 6, 2008 | 03:54 AM
trialsindude's Avatar
Strictly Scionized
Default my CD1 Pro MH
Yeah I know that one is longer than the other, the longer one will be cut to match the shorter one. They are both the mini horn, the flange has been cut to size.
Now I need to get a 4 channel amp and a sound processor.
Also now I will have to dedicate my life to sound tuning these things....
Old Mar 6, 2008 | 05:13 AM
Tcguy85's Avatar
sweet! get them _____es installed! i wanna see them IN the tc. good luck with it all. i hear horns are a pain to dial in.
Old Mar 6, 2008 | 06:45 PM
nodsetse's Avatar
In case you want to talk with someone who's already used those in a tC, check out this thread.
I intend to start on mine soon, but will either use my USD/Speakerworks horns, or a set I made several years ago. It's going to take quite a while, because it's going to be difficult getting 6.5" MBs in the kick panels after I get the HLCDs under dash.
Old Mar 6, 2008 | 07:51 PM
Strictly Scionized
The links to the pictures there are all dead. :-(
Anyways, I test fitted the passenger side, I can stick it all the way to back, basically as far as you can go without hitting the firewall. The driver side will be a challenge since the pedals are in the way. I assume they all have to be equally in depth with each other. So my other thought was to flush fit it where the dash curves down and then flatten out at. If you can picture it with me here! So that the horns are flush with where it curves down at. Basically you can almost see the horn. But if I can do away with putting it deep like the passenger side you won't be able to see it at all.
The other thing I am worried about is imaging height. I've read mixed results with it. Some people end up using tweeters high up in the a-pillars and cross them high like 16k-20k.
We'll see after I piece all the other stuff together first.
Old Mar 7, 2008 | 06:52 AM
rocketgyrl's Avatar
Those are CD-1 Pro drivers mounted on CD-1e horns!
I got to listen to Pete's Scion when he took 1st at World Finals, and then again at CES. It's awesome!
I doubt you'll need additional tweeters. The horn's output will couple to the dash, and the smooth profile of the dash in the tC will cast a near ideal soundstage. The image placement and stability will be spot-on; typical of horns.
Just find a midbass that can keep up! The XS from Image Dynamics are excellent. The CX are junk.
Let me know if I can help!
Old Mar 8, 2008 | 02:53 AM
Tcguy85's Avatar
^sweet! sounds good!
Old Mar 8, 2008 | 08:39 AM
Garage1217's Avatar
ID FTMFW! My new IDQ 12 V3's just came in as well as my new XS65 components. Changing my audio for the oh... 6th time? haha.
Old Mar 8, 2008 | 12:54 PM
Strictly Scionized
But ID isn't no audiobling though :-( I miss SepaTc at a time like this...
Old Mar 8, 2008 | 01:26 PM
Garage1217's Avatar
hahaha, ah the old audiobahn is god forum member. He puts is all to shame with his chrome flame job subs.
carid
Feb 10, 2019 10:46 PM
EVILDAVE
Sep 15, 2015 06:54 AM
JymmyTheSaint
Aug 26, 2015 03:44 PM
5N1PE5
Aug 3, 2015 11:25 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
