Need DIY for NRG quick release setup.
I have an NRG quick release setup and really need help installing it so if anybody knows of a DIY thread or can tell me how to do it that would be awesome. Anybody here that has already done it? How hard is the install? Any tips or tricks I might need to know? Gonna be instaling this stuff Thursday.
Thanks in advance.
Did a search and didn't really find anything
Thanks in advance.
disconnect battery..........
remove the two screws holding the airbag in place.......take off airbag cover.......remove steering wheel harness under neath............remove steering wheel.......not sure if you need a puller or not for the hub.......but I bet it does.......any parts store $12........pull hub.......put on new quick release hub.......attach steering wheel.........
from what I gather the return for the blinkers no longer works without modifacation so when you go around a corner the blinker willnot turn off.......but this is just what I saw on one persons........
never found one that was hard to get off..........have not tried mine yet.......kinda like my airbag.......hope this helps.
i'm not worried bout the airbag cause i've seen more of them hurt people that help. I know they do do some good tho. I am concerned bout the blinker, horn, and cruise control tho.
Thanks for ur help tho.
Yeah u lose that stuff unless u mod it to work. I am just gonna get used to it. Never use the horn plus I have an oogah horn on a switch anyways. The cruise control and horn can be moved but I can't find out how to do it.
I know the blinker switch can be modded with some epoxy and a but of plastic to catch a tab onthe hub and tun it back off.........this is what I did on a GTO long time ago........same concept would work........but it is a pain........
I also need to know how to put the quick release part together. There are two metal gasket looking pieces and a metal o ring looking piece that I have NO idea where they go to.
ok I got everything installed (and even blew the fuse to my Viper alarm somehow...ha ha) and I have one issue. Now when i turn my wheel and let it come back it clicks like it is trying to do the blinker cancel. Does anybody know what this could be and how to fix it?
yeah it is the pilota one. Love it. Very thick inmy hands. I would just like to have the cruise control and blinkers. I have an oogha horn on a switch that i can use as a horn. ha ha
mc1114
Aug 12, 2015 02:07 AM
umnitza
Jul 25, 2015 07:54 PM
myfirstsciontc
Jul 16, 2015 02:40 PM
goatbelly
Jul 12, 2015 10:13 AM
