need help with amp decision...
So, i need some advice on which amp I should decide... I'm looking at a Pioneer and an eclipse. The Pioneer amp is 200 dollars and the eclipse is 300 dollars and I want to get my money worth.
Here is the pioneer:
http://www.circuitcity.com/ssm/Pione...oductDetail.do
Here is the eclipse:
http://www.eclipse-web.com/amp/xa4000.html
Now, should I go with the pioneer or spend the extra 100 dollars on the eclipse? Right now I have a poppy 1200 watt sony xplode amp, which ill just use for my sub, but I want to get a cleaner sound to my speakers and wanted to know which of those two amps would be the best. They're both 4 channel amps and look like what I need to power my two front speakers. They will be powering 300 watt memphis mclass 16-sync components and possibly 260 watt pioneer speakers.
as said above, go with the eclipse. I work at circuit city and have experienced both since we sell both and the eclipse is a much more powerful unit and the power it does produce is way cleaner. less noise, higher quality sound, even on factory speakers. just my .02
Hey i also at circuit city, install, and i agree with all of the posts so far. Pioneer makes good radios but that is about where it ends, unless you spend hundreds of dollars. Get the eclipse amplifier, i plan on getting one if that helps. What kind of continuous power do those speakers require?
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
