noobie ground wire connection.
Originally Posted by gicode0823
for your amp ... where did you get the ground wire from ?
thanx
thanx
What we need to know is are you talking about installing the amp and where to ground it? If that the case it would be advisable to remove the seat to mount the amp. Make sure if there is any to un-plug on the TC seat to do so. It should only be four bolts and then take out the seat. Make sure when you drill through the floor board you do not hit any electrical; or agas lines or the such. Use one of the seat bolts as your ground and make sure there is metal contact foe the ground to be proper.
John
John
took some searching but this should help you...
https://www.scionlife.com/forums/viewtopic.php?t=60981
Nerdcore314
May 1, 2015 11:54 PM
randode
44
Jun 29, 2004 04:19 PM
