Official racing seat thread! post 'em up!
Old Sep 29, 2010 | 04:52 PM
  #301
yellowxhoodie's Avatar
has anyone ever installed seats, then taken them back out and put the OEM seats back in?
I sold my sparcos, put the OEM seats back in and hooked everything up but i cant get my airbag light to turn off...
Old Sep 29, 2010 | 08:06 PM
  #302
GQQSE13's Avatar
i believe you might have to disconnect the battery for it to reset it. did you plug it all back in correctly?
Old Sep 29, 2010 | 08:08 PM
  #303
yea its all plugged in right and ive disconnected the battery multiple times but its still on
Old Sep 29, 2010 | 08:09 PM
  #304
ack154's Avatar
I did that and everything is fine. Are you sure you reconnected everything? I'm not sure what year tC you have... but I had the pressure sensor for the passenger seat and then the little seat position sensor on the driver's seat (attaches to the outside rail).
As long as everything is connected, it should be fine. I didn't have to reset the ECU or anything.
Old Sep 29, 2010 | 09:12 PM
  #305
ugh, this ____ing sucks.
ive double checked everything and its all plugged in.
pass seat weight sensor thing still works and everything.
i also had an aftermarket steering wheel installed but i checked that too and its all connected.
guess ill have to keep checking, wish there was some way to run a diagnostics scanner on it like an OBDII scanner.
Old Sep 29, 2010 | 09:22 PM
  #306
Chrisb319's Avatar
did you replace the seats while the battery was unplugged?
Old Sep 29, 2010 | 09:27 PM
  #307
GQQSE13's Avatar
i was abotu to ask if you still had your quick release on because that would be only other thing i could think of
Old Sep 29, 2010 | 09:37 PM
  #308
nope, everything is back to stock. i really need to figure it out so i can get my car listed for sale.
i dont remember but more than likely i left the battery connected while i was doing it.
Old Sep 29, 2010 | 10:13 PM
  #309
davedavetC's Avatar
you may have damaged the spiral assembly when putting the stock wheel back on, same thing happened to me, i put the stock wheel and seats on at the same time and the airbag light is still on... you can check the air bag system through OBD2 port but you need a special scanner, not one of the cheap ones you get from autozone or something... i use the one that toyota uses that can check everything, even if cruise control is working.
Old Sep 29, 2010 | 10:27 PM
  #310
yea, and if i had to guess the dealers gonna charge me hundreds just to scan the damn thing.
Old Sep 29, 2010 | 10:33 PM
  #311
and how does the spiral assembly affect the airbags?
Old Sep 30, 2010 | 03:34 AM
  #312
davedavetC's Avatar
the spiral assembly is what hooks the airbag up to the harness. along with cruise, the audio controls and the horn. ie. i screwed up my spiral assembly but my audio controls still work but cruise, horn and airbags dont.
you dont have a friend thats a tech or sales person at a dealership? if so ask him to use techstream, its a laptop that hooks up to your OBDII connector.
Old Sep 30, 2010 | 01:37 PM
  #313
damn, thats probably the culprit then, because my horns doesnt work when i press the button on the wheel, yet when i hit the panic button on my keys they do work.
where can i get a new spiral assy without being charged up the assy?
also, how do i go about not messing it up again when i install it?
Old Sep 30, 2010 | 02:18 PM
  #314
davedavetC's Avatar
the only way to know for sure that its not gonna be messed up is to get a new one from the dealership, they are wicked fragile =/
but they are like 200 from the dealer (and i work at one)
Old Sep 30, 2010 | 03:34 PM
  #315
GQQSE13's Avatar
my steering wheels horn worked just if the wire was barely touching it without the reel of ribbon in it (i somehow managed to screw that up and have it fall/unroll when took it off)
Old Sep 30, 2010 | 04:31 PM
  #316
but thanks for the help Dave! I prob wouldve never figured that out on my own, didnt suspect that at all. I wouldve been checking plugs for hours. haha
Old Sep 30, 2010 | 04:40 PM
  #317
so theres no way to look at it and see if its messed up and try to fix it?
i dont know how the ____ i managed to break it.
Old Oct 3, 2010 | 09:39 AM
  #318
domoboiz's Avatar
my corbeau LG1 racing seats black suede.....
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Oct 3, 2010 | 02:33 PM
  #319
davedavetC's Avatar
nope unfortunately i broke 3 of them
but once you spin it 1/4 of a turn too much its dead.
Old Oct 3, 2010 | 03:00 PM
  #320
fml, i dont even want to try to do it myself now. lol
ill have to get a quote from the dealer,
