Optima Red Top ? What size
Old Jan 31, 2006 | 03:34 PM
markritch's Avatar
Default Optima Red Top ? What size
hey im gonna be buying a red top but i see they got a bunch of numbers or group number there are like 34 .... 34/78 ....35 ....75/25 , these numbers are latin to me can you help me out thanks
Old Jan 31, 2006 | 03:44 PM
mandos's Avatar
34/78 first length/width wise, but you'll need a little spacer for the stock tie down.
Old Jan 31, 2006 | 04:36 PM
ScionDad's Avatar
Default Re: Optima Red Top ? What size
Are you using this as a dedicated battery for the audio system? If not, and you are using it to crank the engine as well, I would go with a yellow or blue top. Best of both worlds.
Old Jan 31, 2006 | 05:19 PM
markritch's Avatar
blue top , isnt that designed for marine...i want something with good starting power, cause i got a pretty decent stereo setup ...hid ballasts and all that stuff
Old Jan 31, 2006 | 05:29 PM
mandos's Avatar
I've used a Yellow top in -40 degree weather...cranks the engine fine
Old Jan 31, 2006 | 07:08 PM
ScionDad's Avatar
I guess with the yellow top, they handle discharges and recharges very well with audio system drains.
Old Jan 31, 2006 | 07:39 PM
mandos's Avatar
Indeed.
They keep above 11V for almost their entire discharge, and since they're deep cycle, they'll take a complete discharge many times before biting the dust.
As your daughter found out once...stereo + car off = dead battery
This isn't as bad w/ the yellow top
Old Jan 31, 2006 | 08:10 PM
ScionDad's Avatar
Indeed.
Oh yeah....lasted about 1/2 hour running everything and dead. Now, with the yellow top, she has ran everything for almost 2 hours and still started her car. Huge difference.
Old Jan 31, 2006 | 08:24 PM
peteyd's Avatar
hmm so the yellow top is the better one then?? wats special about the blue one??
Old Jan 31, 2006 | 10:58 PM
-Keith-'s Avatar
By that graph doesnt that mean red top is better?
Old Jan 31, 2006 | 11:03 PM
mandos's Avatar
Graph is for cold cranking amps, which yes...if you do need additional cranking amps, you might want a red top.
But the yellow top is made to handle being totally discharged and recharged again better...better for an audio system and just as good as a stock battery for starting.
If you need additional starting power over stock, Red, if you just want an upgrade because of your stereo, Yellow.
rain7905643
Mar 14, 2015 12:48 AM
blh72
Jan 31, 2015 03:41 PM
George
Regional - Pacific South
200
Feb 11, 2006 01:48 PM
scionlife
Apr 16, 2003 05:13 PM
