Pioneer Premium Head Unit-Preamp Outs?
Old Aug 19, 2006 | 05:22 AM
ferrarif50sport's Avatar
Default Pioneer Premium Head Unit-Preamp Outs?
Does the Pioneer Premium Head Unit have preamp outs and if so what voltage are they?
Old Aug 19, 2006 | 01:46 PM
pb4ugoout's Avatar
well generally it depends on the headunit you are talking about however, I do believe all pioneer premier headunits will have preamp outs. as far as voltages they differ between models. They range from 2 to 5 I believe.
www.pioneerelectronics.com
Old Aug 19, 2006 | 02:06 PM
SCI_TC_GUY's Avatar
give a specific model #... you can generally find specs on crutchfield, sounddomain, woofersetc, ebay, almost anywhere...
Old Aug 22, 2006 | 12:53 AM
sraudio's Avatar
DEH-P680MP has 4Volt
DEH-P780MP has 5Volt
Old Aug 22, 2006 | 01:10 AM
thisisdudewhoru's Avatar
Team Sci-Tech
I think he might be talking about the factory head unit?
Old Aug 22, 2006 | 02:55 AM
pb4ugoout's Avatar
well in that case it doesn't have amp outs...you can purchase an adapter on ebay for around $50 that will give you full range outputs for an amplifier. What the rated output would be, I have no clue
Old Aug 22, 2006 | 10:57 AM
SCI_TC_GUY's Avatar
^^ the output voltage on a LOC should be adjustable via the gain on the converter itself.
Old Aug 22, 2006 | 08:38 PM
I am referring to the factory unit but in the RS2 it has a sub and i would imagine since it has a sub it would have an amp and wouldn't that mean that it has preamp outs
Old Aug 22, 2006 | 08:46 PM
SCI_TC_GUY's Avatar
^^ no, the stock HU has no pre-amp outputs. It used high-level signal (speaker wire) to transfer to the amp instead of RCA's which are low-level signal.
Old Aug 23, 2006 | 01:12 AM
Well i guess my question is this-with the setup in the RS2 would i be able to hookup a new amp and subwoofer with the stock head unit or would i have to buy a new head unit?
Thanks for your help
Old Aug 23, 2006 | 01:49 AM
pb4ugoout's Avatar
if you purchase an amplifier with high-level inputs then yes you should be able to replace the stock equipment with little or no modification. if your amp only has RCA's for input you need to purchase an LOC or Line Out Converter as SCI_TC_GUY mentioned. here is a link to one such unit on crutchfields website...
http://www.crutchfield.com/S-Q4nY0y6...=721&I=142SLC4
there is also a cable you can purchase which plugs inline between the cars harness and the radio which will give you a pair of RCA outputs to connect to an amplifier. It will also provide your amp turn on wire. It's a tad more expensive but in my opinion is a better option. Here is a link to a guy who sells them on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
hope all this helps
Old Aug 23, 2006 | 08:35 AM
Thank you thats exactly what i wanted to know.
Austin292
Scion tC 1G ICE & Interior
Jan 15, 2015 03:52 AM
evolving_machine
Jan 13, 2015 08:04 PM
toyotaisme
Jan 10, 2015 10:24 PM
ScionLife Editor
Dec 6, 2014 11:58 PM
JonathonK
Dec 6, 2014 12:13 AM
