playing videos from ipod to d3
ok so i searched around on avic411 to see how to play vidoes from my ipod to my d3 but just wanted to double check because my didnt get a straight anwer. So is the only way i can play my vieos from my nano to the D3 is by buying a iPod video cable and hooking up the RCAs?
yeah I do have the ipod cable for but it doesn't play the videos, only gives me a blank screen when I switch onto video mode. plays the sound just no image. so where do I hook up the to on video in right?
I have the same problem with my HU. Not Pioneer, but same situation. The sound dealer I go to says any ipods made after 2007 have a new chipset and that is why it is not allowing video to come through. So, I found someone with an older ipod to try it out and I could play video from his.
waiit
if u have the ipod cable for the d3 it should work, u dont need anything else... did u make sure the video on the ipod is set to out, its in video settings.. if not..try just reseting the ipod it worked for me
which ipod do u have?
^^ to the ipod cable? or about what i read?
http://cgi.ebay.com/BLACK-TV-AV-RCA-...QQcmdZViewItem
I think i can find this a walmart or some target.
yea... sometimes you need to check the actual iPod video settings.. I've made that mistake once before.
not sure on the compatibility on the newer iPod units though, much less the nano that you have... so *shrug*
Hyperwhitetc - I ran into this same problem when i first got my D3... The problem (not positive on the new ipod videos) but you have to go into your ipod's video settings. There should be an option that says TV OUT and you have to select it to ON. Theres two other options as well as.. off and ask.. which off obviously is off, ask will ask you to have it on or off. If you having trouble feel free to PM me. But when you set it to tv out - on.. it should play on your d3, only sucky thing is you have to control most of it on the ipod. You only can move back and forward on the d3, you can't select songs. Hope that helps
TheRealShark
Scion tC 2G ICE & Interior
Aug 5, 2015 05:08 PM
umnitza
Jul 25, 2015 07:54 PM
