Plug for Sub woofer/ bazooka ?
your referring to the bazooka side sub correct? you will need a the harness for that sub to your headunit unless you have an 08 with the stock sub and figure out how to hardwire it to that, if not you will have to figure out what each wire of the back of the bazooka box is for and go from there to the headunit. more than likely the wires are ground- 12 volts- constant power- remote lead- speaker signal and i believe those are it
BlingSlade
Nov 20, 2015 06:56 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
