Python 881xp remote start help!!!!!!
hello ive searched quite a bit and either im typing the wrong search words or i just havent found what i need to know.... i need to know which wire i use as the staus output wire. so i can bypass my clutch. i see a wire in the diagram that says status output but it is connected in a harness of wires. Do i splice into that or ???
also there is a wire on my main 12 pin harness that says
(-) remote start activation input... is that used at all? if so where do i connect it?
thanks so much to anyone who can help me out.
Happy Holidays
Happy Holidays
how are you going about bypassing your clutch?
there are two switches on your clutch.. i know i had two on my tc... there should be a blue with white tacer on the alarm brain that you can use to trigger a relay... and on the the remote start brain there should be a blue wire in a four fne plug that you can use as well...
you can use the blue status output wire on the relay pack or the blue/white defroster/ 2nd status output wire on the brain. The (-) activation input is just that, an input not an output. that wire would be used if you were going to use an external unit to activate the remote start on the 881. don't use that wire. hope that helps
airmankevin1
Feb 14, 2018 01:23 PM
mw1957
Mar 16, 2015 06:00 PM
