question about hooking up a LOC to stock unit
Old May 5, 2006 | 02:05 PM
cmwillis's Avatar
Default question about hooking up a LOC to stock unit
I am buying a Dave Navone 2 channel line output converter. Which pari of speaker outputs would be best to tap off of? I was just wasnt sure if their was a difference in the equalization of the rear and front?
For anyone that has bought the stock subwoofer rca connector that go behind the oem radio, what pair of speaker outputs does it tap off of? THat would probably be best to replicate.
Old May 5, 2006 | 03:05 PM
SCI_TC_GUY's Avatar
The rear speakers in the tC are attenuated from the factory.... however, I don't know that this would affect a line output converter.... I know alot of people tap the rears, so I suppose it's your call...
Old May 5, 2006 | 03:21 PM
cmwillis's Avatar
I doubt the attenuation would effect it. I really was wondering if they were eq'd differently. I dont want to tap into them for my sub amp, and find out that there is a cut below 60hz or somethign like that.
Im taking the head unit out either way, and installing the LOC back there. That way i wont have to run RCAs twice, if i decide to replace the head unit in the future.
Old May 5, 2006 | 03:26 PM
L4rry_B1rd's Avatar
tap the rears. that is the common practice for our cars. they tapped the rears on mine, although if your worried about SQ, you might as well just get a new HU. no amount of EQ on the stock HU will make the subs sound as good as from an aftermarket HU.
Old May 5, 2006 | 03:48 PM
mandos's Avatar
Yeah, front or rear, doesn't matter too much.
Happy b-day Mr. Bird....but weren't you 42 yesterday and now you're 40?
Old May 5, 2006 | 03:49 PM
SCI_TC_GUY's Avatar
it said 41 earlier today....
Old May 5, 2006 | 03:54 PM
cmwillis's Avatar
How do those eu-700s sound? Im about to finally hook up my two 9kv.2s to a old pre-dei orion 300wat amp. SHould sound pretty good in this recommended sealed box i built.
Old May 5, 2006 | 03:59 PM
SCI_TC_GUY's Avatar
Not to get too off topic....
the Eu's sound great... get damn loud for being 6.5's for sure!!! They're very user friendly and the sound quality is outstanding..
Old May 5, 2006 | 04:48 PM
mandos's Avatar
Well, it's his topic, he can get off of it if he wants
I like 700s ;)
Old May 5, 2006 | 04:51 PM
SCI_TC_GUY's Avatar
HAHA.... I didn't even notice it was the OP asking me that.... it's Friday, I'm tired...
Old May 5, 2006 | 05:23 PM
cmwillis's Avatar
ONe last question. Not sure if anyone has the answer to this. I plan on using tap ins to make the connections. This way i dont have to cut any of the factory wiring.
I need to the know what gauge the factory speaker and remote wire is?
Old May 5, 2006 | 05:31 PM
SCI_TC_GUY's Avatar
I'd have to venture a guess and say 20
Old May 31, 2006 | 07:23 AM
Cyrus_tC's Avatar
I didn't cut any wires but I was soldering my remote turn on for my amp the other day to the back of the head unit, and i'm pretty sure it was 14 or 16 i used to shed the wire, but I can't be 100% sure ;\
On a different note, for the life of me I can't find anything on the forums about how to actually connect a LOC. If any of you could perhaps give me a run down on where I should solder the wires (I don't want to cut any, since this is my first time doing it). Or if I should just go have someone install it for me (after doing the rest of it, building the box, and even carpeting it myself, and messing with that damn firewall :p) I'd feel it a waste, but I'll do what I have to I guess. Any help with knowing how to put this LOC in would be great.
You can email me at PyrowolfNK@aim.com
Old May 31, 2006 | 08:09 AM
zinker's Avatar
yeah I used the rear in my X worked perfect just make sure you hold down the ssp button and it'll say car type select whatever you have sounds better mine was set on tc on an xb now I'm not mad at it anymore
Old Jun 2, 2006 | 02:19 AM
blackcherry_tc's Avatar
where do you buy the stock rca subwoofer connector???
Old Jun 2, 2006 | 12:44 PM
SCI_TC_GUY's Avatar
^^ you mean a Line Output Converter??? anywhere... Walmart, online, Circut City, Best Buy, any audio shop...
Old Jun 2, 2006 | 04:01 PM
Cyrus_tC's Avatar
I bought my RCA cords at circuit city (they're back with the Amp install kits, same with any store that sells subs and decks generally), and the line out converter i got at a place her in Colorado called Car Toys (i don't know if they're just local or what, but there's a good few of them across CO). The only problem I'm having is finding the correct 12+ V wire on the back of the stereo for the remote turn-on wire, and the 5 wires i need to tap into with the Line Output Converter
Old Jun 2, 2006 | 04:33 PM
cmwillis's Avatar
I didnt cut any wires, solder, or take out the radio. I just tapped the rear speaker wires where you can see them under the rear trim panels, where the back speakers are mounted. Look for the wires with silver marks!!
I used wire taps, just liek the ones that come with the rear view mirror. WOrks great. Got my acc from near the fuse box using the same tap.
TotalChaos
13
Feb 4, 2015 10:24 PM
billzor
Scion tC 2G ICE & Interior
Jan 17, 2015 12:38 PM
lunchbx05
Dec 11, 2014 06:13 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
ToyTuners
Nov 4, 2003 07:17 AM
