Re-Painting these Interior Pieces...
I originally painted my interior peices gunmetal and now I am wanting to change them..what I used the first time was krylon gunmetal paint...long story short..i sanded it down a bit and began shooting the new color and it was looking all good...then when i went to put on some old clear coat...i came back and wwas in shock to see that apparently the clear coat i used ate through the paint and caused all these little cracks..at this point i tried taking everything off but it left me with a surface more uneven then an off roading course surfavce....ive used acetone to take off as much as i could but as anyone who has used it before with these two thick layers of paint (10 coats probablky including first paint job and secound) it is pretty hard to get it the way it was...so i sanded it and sanded untill i could get it as smooth as i could and now there are still remaining cracks and bumps meaning that if i do spray this again it will obviously come out bad..
My question is...can i use something like filler primer to make the surface smooth again or...? do u think its the end of my piece...thanks in Adv.
Kishan P.
Kishan P.
haha try 70 bux for each water fall plastic piece under the head unit.....74 for the gauge cluster...and i didnt even ask for head unit..
Kishan P.
Can someone tell me if filler primer will work though?
Kishan P.
Hmm... might have already closed. I don't recall exactly when it was... let me check.
Ah...
http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
Closed already. Not sure if it was high or not though - but a lot of pieces I think.
Ah...
I think it'll be fine.
Bondo filler, sand, primer, sand, paint, sand, paint.
I also used clear coat on one of my paint job projects and it ate the paint and made it look cheap. Had to redo it all over minus the clear coat.
Hey sorry for the long time no respond hash..here is a pic of the gunmetal and some other paintings I've done...
I tried to sand and sand and filer primer and sand but what i came out with is'nt nearly as good as the stuff below...
that looks nice the one thing i painted that u didnt was the center consol air vents the spot u left black it looks way nice white it was a bit tougf to sand but i got it nice and smooth big ups kissasskishan
hhaa thanks man but this sucks major ___ bc i cant get it smooth like stock i tried for aabout 30 mins on 1piece sandwed---filler primer--sanded --filler primer--sandded--painted there are just bumps and ish ____ing me off i gues im going to have to get new stock pieces..:'(
Kishan P.
Kishan P.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Pack34
Scion tC 1G ICE & Interior
Sep 27, 2015 07:11 PM
