REMOTE START QUESTION
You should look at DEI brands (Viper, Python, Clifford, etc.)
Also, if you're not well versed with wiring, using a DMM, soldering, wiring relays, etc. I suggest you take it to a professional. It isn't hard but at the same time i've done them on easier cars, i.e. any Honda.
Furthermore, if you drive a base tC you will need the DEI bypass to bypass the tC's transponder system or your car will never remote start successfully. You should look into the bypasses that work without you needing to lose your 2nd key, they cost more but they're more secure as well. If you drive a spec tC, disregard that last statement as they do not have the transponder system.
Just go with this... and yes, you'll need the transponder unit.
http://www.viper.com/P-4203V/Viper-R...e-Start-System
what would i need to get/do to get this to work for the tc.
all i want is auto start, not new security if you know of any other ones let me know!
CLICK!
CLICK!
go here: https://www.scionlife.com/forums/sho...d.php?t=177771
1, what you posted is hardly a diy.
2, what you posted has nothing to do with how to get R/S withOUT an alarm like the op asked.
op, check the12volt.com can be done with a few relays. or best buy should have a R/S only for around $50bucks. im pretty sure JCwhitney sells one too.
http://cgi.ebay.com/Ultra-Start-OS12...ht_6463wt_1167
scionspecialistvegas
12-15-2003 11:21 AM
