rocker switch installed
i got a OEM rocker switch for my car im goin to be putting in some lights this weekend. and i was wondering if anyone has pics were they installed one and were they pulled it into in the fuse box. i dont want to run a wire all the way to the batteries i want to just run it to the fuse box. can anyone help me.
huh .. man .. the switch got 2 terminals .. and each of them just go between the power wire for your lights .. know wat im sayin ? .. one side goes to the light power wire and the other side goes to the fuse box right there .. got it ?
Originally Posted by Cabana
Do you have pics? I'm looking for a switch to replace the crappy one the audio shop put in my car...something that would look OEM to the left of the steering wheel.
Home depot used to sell them as well/ i picked up one for my neons and one for my leds. They look oem. Easy to wire too. TWo prongs, one for power in and one for power out. Make sure to find a good screw to ground it to.
As for the fuse box question get an add-a-fuse, they are like $6 at advanced auto. You connect the power wire to the add a fuse, pull a fuse, plug in 2 fuses to the add a fuse, and plug the add a fuse into the fuse box, very clean and no loose wires stuck in your fuse fox. I used the taillights one on my xB
I got my switch in and kinda messed up the larger piece of plastic in the process, is it possible to buy a replacement?
Also what's the best way to pop out the panels without ____ing anything up?
randode
44
Jun 29, 2004 04:19 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
