short circuit
Old Jun 15, 2008 | 11:55 PM
patternofstars7's Avatar
Default short circuit
I got my new gauge face and leds done but apparently I have a short circuit somewhere. Probably from my Avic-D3. Probably taking it to the dealer tomorrow which i'm sure they'll charge me a buttload to fix. Any suggestions?
Old Jun 16, 2008 | 12:39 AM
O5_TRD_tC's Avatar
who installed the avic?
Try to locate the problem first. Then change the fuse and see if it continues to blow.
Old Jun 16, 2008 | 12:43 AM
my friend and i. i'm not the most knowledgeable person with this stuff so he was pretty much leading the way. any ideas what could be shorting it?
Old Jun 16, 2008 | 01:37 AM
engifineer's Avatar
What is happening to make you think you have a short? Blown fuse?
Old Jun 16, 2008 | 02:37 AM
combatsteve's Avatar
^x2
my suggestion is not to take it to the dealer
Old Jun 16, 2008 | 02:44 AM
repeated blown fuse.
Old Jun 16, 2008 | 02:48 AM
engifineer's Avatar
Which fuse? If you think it has to do with the stereo, my first recommendation is to unplug it, then see if the short continues.
Old Jun 16, 2008 | 02:59 AM
I forget which fuse it is but it controls the lights of the waterfall and dash lights. I think that's what I'll do tomorrow after work. I'll unplug the radio and test it out. If it is the radio what could cause the fuse to blow? Bad crimping?
sorry for all the noob questions.
Old Jun 16, 2008 | 08:24 AM
datdude1119's Avatar
just check all of the wiring, if any of the wiring is touching metal pieces then that can mess it up, if its hooked up to the wrong wire that could mess it up. id say there was no need to take it to the dealer, just fix the wiring on the radio.
example..
me and my friend installed a amp kit and amp in his 06 mustang gt and every time we went to turn on the car, it wouldn't do anything, turn the key..seemed like nothing happened..turns out we kept blowing ignition fuses, and it was all because one wire had been pinched up against the frame.
Old Jun 16, 2008 | 12:50 PM
engifineer's Avatar
I am guessing you have a bad connection that is grounding to something on the car, or you have tied in the dimmer control wire for the unit to the wrong wire in the harness. Seems that I have heard of a few others that had issues with the dimmer control wiring on that unit being connected improperly.
Old Jun 16, 2008 | 10:04 PM
Thanks everyone for the info. My friend and I just checked all the wiring and fixed it all up. Two fuses ended up being blown. Replaced them and now everything is working perfectly
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
airmankevin1
Nov 17, 2015 05:44 AM
excessads
Sep 15, 2015 05:28 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
