some fun with LEDS
Old Sep 5, 2007 | 08:26 PM
LiquidTension's Avatar
Default some fun with LEDS
So i have some spare time now and I was thinking of adding some more leds to the mix. I'm thinking of putting blue leds somewhere in the door panel so when I open the door, they turn on. I would like to do a line towards the bottom edge of the door (possibly 5 or 10 leds) however, i want to know what you guys think.
I want to stick wth Oznium because I have had nothing but good experiences with them. SO.....should I use the 4 chip superflux, the regular prewired, or possibly one of LED strips?
Old Sep 5, 2007 | 08:30 PM
SquallLHeart's Avatar
hmm.. if you want that spotlight VIP look, that rules out the led strips...
but if not.. then that would be easier to deal with.
Old Sep 10, 2007 | 08:18 PM
bump... for one more question
If i want these leds to turn on with the dome lights (that is when the door opens really) do I just tap into the dome light? fused indepedently or not? and where would this wire be located / color? thanks guys
Old Sep 10, 2007 | 08:45 PM
ScionJim23's Avatar
you want to tap the blue (negative) dome light wire to do this. Its located under your switch panel behind the pull out cover. And then obviously run 12v constant power to it.
Its real easy Good luck.
Old Sep 10, 2007 | 09:00 PM
i just had a fused power source to the lights.. and then tapped the ground that the dome lights go to when you open the door or unlock the car.
i used the blue wire, pin 2 on the 1K connector that goes into the inside instrument panel j/b
but the orange on 1E, pin 27 is another option too.
as far as positive... yeah.. people have been using that spot in the pic above... but i dunno. if it works... but yeah.. the blue wire i mentioned is the same negative like in the pic.
Old Sep 10, 2007 | 09:16 PM
ScionJim23's Avatar
yes sir....x2^
Old Sep 10, 2007 | 10:40 PM
sweet - thanks...ill let you know how it goes and possibly post pics later
BlingSlade
Sep 5, 2015 08:52 AM
umnitza
Sep 1, 2015 08:06 PM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
StxArOne
Jul 13, 2015 06:25 PM
