Squeeky brake pedel.
Originally Posted by i007spectre
Does anyone elses brake pedel squeek when you push it.
Its a little annoying.
My CLUTCH pedal/assembly USED to squeak incessantly. But after five tries, the techs finally "lubed" (yeah rite) the assembly and not a peep since
wait...this is a noob question....how do u knw its the pedals? how can i tell? its seriously embarrasing, i just havent had time to go check on it. i heard it could be weather change issues, here in texas. its more intense when im braking slowly like when at a drive thru, thus makin it even more embarrasing.
if you're hearing the squeak primarily Inside the car and you think its originating from the brake pedal itself, it may just need to be lubed.
if the squeaking sound is coming from OUtside the car, like from the wheel well while you are braking, then probably your pads are worn down and the indicator tab is scratching against the rotor to let you know its time for some new ones.
if your a noob, just take it to the dealership and make them do it.
Originally Posted by badseed305
yes. its the abs working its magic. normal.
ABS does not squeek. ABS does make a "grinding" "pounding" noise when it is activated. Trust me, you WILL know when ABS has kicked in.
For the record, I live in the snowbelt of the northeast, so ABS kicks in fairly offen during the winter season, even with 4 winter tires.
My opinion, ask a mechanic to check the surface of the rotor or the pad life. My friend had a rock stuck between the rotor and pad and ended up digging a channel in the rotor surface. Ended up having to replace it...
Klashan
Sep 24, 2015 12:39 PM
