Are there RCA INPUTS on the back of the stock deck?
Old Dec 30, 2005 | 01:43 PM
JW2's Avatar
JW2
Default Are there RCA INPUTS on the back of the stock deck?
I am trying to hook up my Sirius receiver. When I go through the input in the center console I get really bad alternator whine through the speakers. I bought a radio shack ground loop isolator but it just changes the noise from a whine to a buzz.
I was thinking I'd try to go in through RCA inputs if the deck has any. Does anyone know if this is an option? I am fed up as this Sirius radio was a gift with a 1 year subscription and I can't use FM modulation because I can't find any clear stations that do not have any signal on them.
Old Dec 30, 2005 | 02:08 PM
SCI_TC_GUY's Avatar
No rca inputs on the back of the stock deck....
Have you tried a wired FM modulator??? like this:
http://www.autotoys.com/x/cust/produ...cat=196&page=1
Old Dec 30, 2005 | 03:07 PM
JW2's Avatar
JW2
I actually haven't tried that yet... I wonder if it would be subject to the same noise as I'm getting now? Also, I forgot to mention that even if I unplug the power from the Sirius receiver but leave the aux input plugged in, the noise remains.
Does that wired FM adapter still allow you to listen to the regular radio through the antenna as well? Sorry, I'm not familiar with these devices.
Old Dec 30, 2005 | 03:14 PM
JW2's Avatar
JW2
I looked at it again and it looks like I answered my own question...
By the way, the reciver I have is the Sirius ONE which I plan on mounting in the hole beneath the stereo. The receiver has an Audio out, which is the 3.5mm mini-jack, and also a FM out which is a 2.5mm plug. What is that one for?
Old Dec 30, 2005 | 03:15 PM
WeDriveScions's Avatar
PIE Makes an adaptor for our stereos that adds RCA input to our decks...
A search for PIE RCA stereo should do the trick for you.
Old Dec 30, 2005 | 03:20 PM
JasonH's Avatar
You don't need that modulator, you could just try this. I didn't have any trouble using the built-in FM modulator, but I wasn't happy with the quality, so I tried the wired adapter. It didn't make any difference in quality, but it should eliminate any outside interference.
If you want to wire it directly into the head unit you can buy a USASpec DF-TOY aux input adapter for $59.99 at Circuit City. It plugs into the CD changer input and has two sets of inputs. I did that and I have a little whine right now, but once I stop using the cigarette lighter and hard wire the power to the Sirius receiver it should go away.
Old Dec 30, 2005 | 05:40 PM
JW2's Avatar
JW2
That's perfect! But every place has them on backorder :-/ I guess I'll have to wait.
As a side note, I went out to my car at lunch today and plugged in JUST the cable with nothing attached to it into the AUX port in the center console and it made that terrible alternator whine noise. Something is ****** up with the Scion input I guess.
Old Dec 31, 2005 | 03:32 AM
JW2's Avatar
JW2
I found one at a Circuit City on the other side of town... went over and got it this evening. I will try it out tomorrow and post the results. Thanks again JasonH
lunchbx05
Dec 29, 2014 07:53 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
Docofmind
Oct 25, 2003 04:33 AM
MaxPower
Oct 22, 2003 09:22 PM
PhiDeltMatt26
10
Oct 7, 2003 02:00 AM
