TRD Short Shifter
Can someone update me on the TRD Shifter install? I'm not so much worried about installing the shifter as I am about removing consoles, etc... without breaking cheap platic clips and such... I don't really see a lot of screws, you know?
its all clips. Pull the shifter console area up with your finger nails under where it meets the console. Slide it up and it will pop out. Make sure to disconnect the cig lighter before pulling to far away. Its real easy.
hmm.. remove the center armrest big piece are two 10mm bolts inside the armrest and two screws where the shofter area is... then plug to disconnect... and move that out of the way and you'll get plenty of room.
simple philosophy of tC gutting: if you don't see/can't find a screw, nut, or bolt... it's probably a clip and just yank away.
yea.. he needs to remove the whole cage assembly (trd short shifter)
... unless you want to have a nice time reaching to get to the back bolts and to remove the cables.... it's easy to just get it out of the way.. it's just 2 plugs, 2 screws and 2 bolts... will make it ALOT easier.
i forgot it was the whole assembly. While your at it, shorten the shifter arm by cutting it. I did mine yesterday and put a new shifter **** on. The shifts feel so much better.
I mean does it really change the shift time all that much? I know the TRD says it shortens by 30% or 35% but is it really worth $525? Also how much is the twm stage II cost? If it works as good as the TRD and its cheaper I might go with it. I'm just wantin to know if its worth buyin or not.
Thomas
Thomas
Ok well I found out from the dealer that the TRD is $335 but I was lookin at another post on the TWM Stage II and its only $144 and some odd change. I'll probly get that since it lowers the shfiter 2.5" and reduces the throw time by 35% and it looks nice on a tC. The lowered 2.5" makes it look like a new '06 Mustang Shifter. I know this coz I looked at the pics of the TWM tC install and my friend has a '06 stang 5-speed. That thing will roll lol.
Thomas
Thomas
Thomas
Thomas
just get the twm stage 2 short shift kit....if i remember, it was a little over $100, or something like that....install was pretty straightforward, and with a weighted ****, you can shift much faster...especially good for the track!
www.twmperformance.com find your car its only like $144. I'll end up gettin one soon most likely.
Thomas
Thomas
carid
Nov 24, 2015 02:57 PM
NonStopTuning
Jun 29, 2015 07:42 PM
