trouble removing PCB board (cetner console)
Old Sep 30, 2006 | 08:29 PM
krnkawoo's Avatar
Default trouble removing PCB board (cetner console)
i did my gauge lights yesterday and doing center console today and having trouble removing the PCB board from the center console plastic case. i removed pretty much everything. even unscrew those 4 screws that hold PCB and plastic case together (excluding 2 screws that hold LCD). it should comes right off but somewhat it doesnt. can anyone help?
Old Sep 30, 2006 | 09:15 PM
blunt14's Avatar
I think what your missing is under the know that controls the temp... gently pry that the **** off, and I believe its a twelve mm nut that holds it all in.. and after getting that out, it should release the board from the cover.. hope this helps ya..
Old Oct 2, 2006 | 06:41 AM
LEDmod's Avatar
It was really hard to pull the **** off...
I did mine and friend's and it was pain in the a$$ to pull it out....
I've just lift it little bit there is like 3 holes and you can push it in with some fine point and lift and **** cover will come off and you can pull out the clear plastic **** hard as you can with plier.... then there is a nut you need to remove....
Old Oct 2, 2006 | 06:47 AM
SquallLHeart's Avatar
11mm nut.
and next time.... after you remove the 6 screws... just push from the front on the buttons so the unit slides out underneath leaving and taking off the ****.
no prying necessary.
Old Oct 2, 2006 | 07:10 AM
LEDmod's Avatar
I'm just worry that if you push through like that, **** base might crack at the circuit board....
Old Oct 2, 2006 | 09:02 AM
......? what makes it any different from prying off the **** with a screwdriver or any other tool and possibly scratching/mutilating the **** unnecessarily?
i think i've taken apart the console many times enough to know what works best.
remove 6 screws... no need to take apart the unit yet (the plastic back.. unlike so many people do...)
remove the unit with aforementioned method... remove hazard button, remove nut... then open the unit... remove screws.
RY_TC07
Jul 18, 2017 05:18 PM
wrelkin123
Scion tC 2G Aero & Exterior
Jun 10, 2015 11:53 PM
trikkonceptz
Jun 7, 2015 01:46 AM
randode
44
Jun 29, 2004 04:19 PM
