TUTORIAL: LED SWAP IN STEERING WHEEL CONTROLS & DOOR CON
Old Aug 9, 2006 | 04:50 AM
LEDMods_net's Avatar
Strictly Scionized
Default TUTORIAL: LED SWAP IN STEERING WHEEL CONTROLS & DOOR CON
Okay, I finally decided to take some extra pictures and do a tutorial. Enjoy!
The LED's needed are 3 PLCC LED's, and 5 1206 LED's. If you need some good ones, I have them for sale.
(Click the pictures for full size image)
STEERING WHEEL CONTROLS:
TOOLS NEEDED:
- Torx 30 Bit
- Phillips Screw Driver
- Snips (to cut 1 zip tie)
Step 1: Remove the torx screws on either side of the steering wheel. This will allow you to access the screw for the steering wheel controls. When you first unscrew the screw, you will have to turn hard. you WILL hear a snap. Don't worry, this is the screw coming loose. You don't have to take out the screws! Just leave them in there, but make sure they are loose.
Left Side
Right Side
Step 2: Gently pull back on the air bag unit. If it doesn't easily come out, try loosening the screws some more. You can let it rest on the wheel. DO NOT UNPLUG THE AIRBAG!! If you do, disconnect the negative battery terminal. Wait until the mod is finished, plug in the airbag, and plug in the negative battery terminal last.
Step 3: Unscrew 1 phillips screw that holds the steering wheel control box in.
Step 4: Pull out the control box.
Step 5: Cut the white zip tie that holds the wires to the box. Unplug the harness.
Step 6a: Disassemble the box, desolder the LED's, and replace them with your new ones! (I didn't take many pics of this step).
Step 6b: Ship the box to me to mod!
Door Control Mod:
Tools Needed: A good prying tool
Step 1: Pry up the door controls. Start at the back side of the controls. After you pry it up, you will slide it out. Unscrew, disassembly and mod (or send to me to mod). :D
The finished product!!
Old Aug 9, 2006 | 05:14 AM
FLEA's Avatar
Nice, I still need you to do the LED swap on my gauges, HVAC, steering wheel controls, and doors. But with a full time job I can't give up my car for more than 1 day.
Old Aug 9, 2006 | 05:40 AM
Strictly Scionized
Let me know when you have a day off, and well get it all done in 1 day. I'll PM you my contact info.
Old Aug 9, 2006 | 06:16 AM
SquallLHeart's Avatar
hmm.. daymn.. i need one of those prying tools..
i've been just taking the door panel off...
Old Aug 9, 2006 | 06:28 AM
Strictly Scionized
Lol! I almost did that.
My hook tool is from Sears (I think). A lot of my hand tools are craftsman (for the warranty). Just go there and get a hook tool (I don't know the real name, thats what I call it).
Old Aug 9, 2006 | 06:37 AM
theblue's Avatar
hey whiteblazer01, can you PM me your location info for this weekend? thanks
CombatmedicR56
Nov 12, 2020 01:53 AM
evolving_machine
Jan 13, 2015 08:04 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
