wiring colors for tc
Old Oct 29, 2006 | 01:50 AM
Scionarra's Avatar
Default wiring colors for tc
i was wondering if there is a thread for the wiring colors on the tC or is it the same as the xA or xB? if there isnt, can anyone tell me where the wiring harness for the ignition power wire is on a tC and which color wire is for the ignition bc thats where i plan to tap for constant power to go to my underbody LEDs.
Old Oct 29, 2006 | 01:58 AM
ProshopXB's Avatar
05 Scion tC- Wire colors
Wire: Wire color/ Polarity / Location
12volts: red or white/ + /ignition harness
Starter: black / + /ignition harness
2nd Starter: green / + /ignition harness
Ignition: blue / + /ignition harness
2nd Ignition: yellow / + /ignition harness
Accessory: gray / + /ignition harness
Keysense: black / - / ignition harness
Power Lock: green with blue stripe/ - / driver kick, 20 pin plug, pin 15
Power Unlock: purple with pink stripe (double pulse)/ - / driver kick, 20 pin plug, pin 14
Parking Lights: brown/ + /top of fuse box, 30 pin plug, pin 29
Parking Lights: brown / - /headlight switch
Reverse Light: pink / + / top of fuse box, 14 pin plug, pin 2
Door Trigger: orange (D), blue (P)/ - /top of fuse box
Dome Supervision: blue/ - /L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin: purple/ - /top of fuse box, 30 pin plug, pin 7
Trunk/Hatch Release: orange/ - /driver kick, gry 12 pin plug, pin 12
Tachometer: black / ac / data link conn. under dash, pin 9
Brake Wire: blue / + /brake pedal switch
Parking Brake: black/ - /parking brake switch
Horn Trigger: white / - /horn switch
Old Oct 29, 2006 | 06:46 AM
Scionarra's Avatar
will the red or white 12volt wire from the ignition harness always be hot? regardless?
Old Oct 29, 2006 | 07:38 AM
SquallLHeart's Avatar
uhhh... why don't you just hook it up directly to the battery for constant power..? that's what i did...
nothing's more constant than hooking it up to the source.... just ya know.. fuse it.
bktply
Scion tC 2G Aero & Exterior
Mar 16, 2015 06:15 PM
MonsterunderBed0
Feb 17, 2015 08:42 PM
fliggah
May 28, 2004 07:51 PM
DirtyThirty
14
Jan 16, 2004 04:48 AM
abbfanuc
Oct 21, 2003 05:16 AM
