Wiring question
Old Jul 11, 2006 | 03:35 PM
kenneth520's Avatar
Default Wiring question
I have a 05 scino tc. I wanna get a 06 steering wheel and wire the radio control to my AVN5435.
Do you guys know if it is possible to do this wiring?
If yes, please instruct
Old Jul 11, 2006 | 07:12 PM
SquallLHeart's Avatar
hmm.. it'll cost you more than it's ever worth it.
i'm just going to say it's impossible.
Old Jul 11, 2006 | 07:13 PM
kenneth520's Avatar
can you tell me how ? and what make you think it is going to be expensive?
Old Jul 11, 2006 | 07:15 PM
the wiring necessary is not present in the '05.
i wanted to swap out my '06 steering wheel with a buddy of mine.. but it was impractical to do so.
speaking to my buddy at scion, he told me that the wiring necessary would cost alot... he told me maybe around $800.. and then installing it would be a job in itself....
Old Jul 11, 2006 | 07:17 PM
kenneth520's Avatar
the wire itself cost 800?
it is just a smalll custer with 8 wire in it..... I think it is a dealer price.
Old Jul 11, 2006 | 07:29 PM
SPattle's Avatar
Im not sure, but if you got the 06 head unit and the 06 steering wheel, it wouldnt be too bad.
Old Jul 11, 2006 | 07:31 PM
kenneth520's Avatar
steering is easy to get, but the whole head part is hard to find and it may cost a lot
well.. if you find a way... post it up. i want my '05 steering wheel without screwing over my buddy that won't be able to use mine.
Old Jul 13, 2006 | 08:59 PM
jetlounge's Avatar
i think you are on the right track, and 800 is ludicrus.
you need the steering wheel, the harness you mentioned and then the PAC SWI-ECL if your Eclipse has a steering input. If it doesn't you'll go with the tried and true SWI-X which adds and IR eye. i don't understand why you would need the head unit at all.
Check with pac-audio.com on the conversion unit. And just contact your dealers parts area for the harness part# for the steering wheel. The question is will they simply sell that 8 part wire or do you have to get the entire audio harness?
Or maybe you can get one off a junker?
Old Jul 13, 2006 | 09:12 PM
kenneth520's Avatar
I just wonder if someone has done something crazy like that.
I have no idea how to mod it, but I wish to hear someone who is very experience in it.
Old Jul 14, 2006 | 01:45 AM
Yanki01's Avatar
just get a HU with a remote?
Old Jul 14, 2006 | 01:01 PM
jetlounge's Avatar
i don't think it's that complicated. but your first step would be to find out if you can get the harness and what it costs.
Old Jul 14, 2006 | 07:08 PM
kenneth520's Avatar
There are tons of totaled car that we can get the harness from. Just a matter if it is possible to do this mod. I need instruction
Old Jul 14, 2006 | 08:07 PM
jetlounge's Avatar
steering wheel --> harness --> PAC Audio unit ???
be adventurous. i would try it. i could be wrong, but i don't think a simple test would require the harness to even draw power. you just want to link up the little white plug on the back of the steering unit to the colored leads. with that simple test you won't get the illumination, but that would be secondary. Give pac audio a call they can tell you about the units they sell. if you are less adventurous you just go with the IR unit they sell.
and where are you finding totaled tcs in NY? I need some replacement parts.
Old Nov 12, 2007 | 12:50 PM
mybmw530i's Avatar
You can connect the steering wheel controls to an alpine radio. If you have a 2005 TC, you can install steering wheel audio controls on the steering wheel (the steering wheel would have to be replaced), and connect it to an aftermarket radio. I have done it.
Old Nov 12, 2007 | 01:28 PM
kenneth520's Avatar
you have done it? can you showme the wiring process from the steering wheel to the radio area?
Old Jan 5, 2008 | 04:22 PM
mybmw530i's Avatar
I have a 2005 Scion TC and added a new steering wheel with audio controls and tied it to my Kenwood. It does work.
Old Jan 5, 2008 | 05:44 PM
tweetertc's Avatar
well... dont forget guys... there will be a module on the steering column for the steering wheel controls... cause your steering wheel has to be able to turn... so there is a lot more to this than most of you think... i would imagine that the way the steering column is you will have a rough time putting in the module... cause its wants designed to go in the 05's and you have to run the wires down... i can guarantee that it needs a acc 12volts, and ground... and maybe even a 12volt cnostant... its sounds overly complicated and way too much freaking money to get a so so out come..... just me...
Old Jan 5, 2008 | 07:20 PM
mybmw530i's Avatar
No, it's actually pretty simple. The radio controls on the wheel plug into a connector on the fron of the steering wheel. This connector passes all of the signals through a ring on the steering wheel. On the other side of the steering column is the other end of this connector. All you have to do is purchase a mini connector (toyota - on Ebay) and this will give you the ability to tap all of the signals.
Old Jan 5, 2008 | 07:21 PM
mybmw530i's Avatar
The connector then mates up with a PAC unit to control the stereo.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
vpkb
12
Oct 8, 2003 04:17 AM
