xbox 360 in tc, help!
I was wondering if ne body has put in an xbox 360 in their tc. im working on putting it in mine, i have it connected and every thing, but i have a few issues.
1. the battery isn't giving enough power to the power converter, the 360 only works after a while the car as been on.
2. i can't find a good spot to put the 360
3. i blew a fuse haha, my under dash led's, cup holder, under seat wont turn on, my sunroof wont open, and at night, when my lights are on, the lights on the window buttons blink haha
would like help on all three of these issues
you tapped the battery for your 360 right?
battery -> fuse -> inverter -> 360
just make sure you get a fuse that can handle the amount of power, and you shouldnt have any problems.
and yea... it does suck a lot of power, so i would only play it after the car has warmed up - since as tempature goes up, resistance goes down.
you think? or you did lol
its not that hard to mess up, unless you tapped a pre-existing fuse.
you have to tap the battery directly, and when you said otherstuff blew up, it leads me to think you didnt tap the battery directly.
Maybe I have missed something, but from what I hear the 360 will trash a disk if you even think of moving it while it is running (tilting I hear causes disk crashes in them easilly). Unless I have just not been keeping up with the 360 (which could be the case lately) then you may want to check that out. I have heard of a good few moving them from laying down to standing up while running and trashing a game.
You need to buy a 0 gauge kit from an electronics store, or car audio store. They are the same kits used to hook up high power amplifiers. I'm sure if you go to any of these stores, they will be able to supply you with the necessary kit and fuse. And then just like i said before
Battery -> Fuse -> Inverter -> 360
I am putting one in my Xb and I am just running the yellow top Optima, seems to be fine....however I will caution you...you need to make sure the 360 gets plenty of ventilation, I am mounting mine on one or the fan bases that run off of the usb port of the 360, you do not want to try and hide the 360 with no ventilation. Good Luck!
i see isee, thanks for the heads up. But i just got a taste of the "don't move the 360 that much with a game inside", Tony Hawk project 8 works no longer =( prettty lame. and how much did that yellow top cost you
alright, and, even tho your putting your xbox in your box (
) where do you think would be best place for the tc? i was thinking glove box but its out like one inch, andddd, i was thinking of cutting out some of the glove box to fit it thru butttt, iono if that is a good idea haha
yellow top battery. get a inverter that can carry as many amps as the 360 needs (cause i know that sucker needs alot).
and checck here for the other problems:
http://home.cfl.rr.com/icdedppl/faq.html
tells how to reset stuff.
