1st to 2nd gear grinds on a cold start
I have an '06 tC. I have driven a stick shift for years, but with this car, everytime I start it up for the first time in a day (had been off for approx. 10 hours), first gear gives me no problem, but going from first to 2nd, there is a grinding in the stick. This only happens the very first time that I go from 1st to 2nd, and only on a cold start. Every other time that I shift, it is perfect. The grinding in the stick is frustrating me, anybody have any advice or ideas?
I don't usually give it any more than 5 seconds after I turn on the car to start driving (the amount of time it takes to put on my seatbelt) It just happens once a day, the very first time I turn on the car from a cold start. When i turn it on 3 hours after I last turned it off, then no problem - just that ice cold start.
Yeah i have that too, and i have the 05 model. It's only the first time when shifting to 2nd..it feels wierd and is annoying i know, i dont think there is anything we can do about it since it goes away after that, i think it's because the fluids havent quit lubed all the gears yet. I dunno...but mine does tha too in the morning from a cold start.
Originally Posted by scoobyroo2002
IT's summertime! no need to really warm the car up! it's like 100 outside when i go to start the car. HA! Now in the winter i let my car warm up for about 5 to 10 minutes before i go anywhere.
Music City Scions
The trans doesn't warm up untill after you start driving. If it doesn't get worse,live with it. Otherwise have the dealer check it out. Sounds like a problem with the syncros.
Try shifting into third instead of second and see if it still does it.
Originally Posted by harrisch
try not going straight into second and pausing for a second in neutral
I have tried that as well. And I also have tried depressing the clutch ridiculously hard when doing it. The one thing that I haven't tried and I will do tomorrow morning, is to back out of my driveway and go right into second rather than 1st. Thanks for the suggestion (I thought it would work as well). Anyone else have any other ideas?
I would bring your car rightback to the dealer. Leave it there overnight so they can see for themselves exactly what you are talking about.
You should never hear any grinding, unless you are low on hydraulic fluid or the rack is somehow damaged.
I was hearing the same type of grinding on my 2000 Excel. The grinding was always on the downshift between 1st and 2nd gear.
Would never happen when the car was warm. Only happened when the car was cold in the morning.
I left the car at the dealer overnight and they determined it was the the gears gringing into the tranny rack. Somehow they weren't lined up correctly. Anyway, they ordered the part from California. I was without my car for 1 week, but it was completely covered by the new car warranty. However a rental car was not in the warranty aggrement. The dealer fixed the problem and I have never had the problem again..
Hmmm well i have heard a lot of people have this problem with the tC. I thought it was just normal...i mean it's annoying but it's only second gear and it's only once it's the first shift while taking off...after that it wont do it again. I am not sure if it's worth losing my car for a day or week or whatever....but if it moves to all gears..then yes of course i will take it in.
Good point, but I figure that if it does become worse in the future, they will have seen that I brought it in previously.
Thinking it over, I don't think that it has much to do with warmth of the car, because I can go into second, to neutral, and then back to 2nd within 2 seconds and it doesn't happen anymore. I believe that this rules out tranny warmth. I am going to bring it to service and I will post another thread then and let you guys know what happened.
Being that this is not a problem with JUST my tC, that makes me feel a bit better.
Anyone else think of anything?
let your car warm up more than 5 seconds. what i do is start the car, then push in the clutch and run the shifter through all the gears, then let out the clutch in neutral. i haven't had any grinding in second since i've started doing that
here is the post i was refering too. as i said previously it was the bushings. hope this helps
https://www.scionlife.com/forums/viewtopic.php?t=62589
