How Do I Remove Door Panels in Scion tc
the outer edge of the "handle" pops off... look towards the front part of it, you will see a groove. put a small flat-head screw driver in it and gently pry. then pull the rest with your hands (hint: the plastic peice u need to pop off is attached to that "accent ring" with the chrome ring)... you will then see 2 phillips screws. remove those. also make sure you remove the one phillips screw behind the handle u pull to open the door. after the 3 screws are out... from the bottom up, gently pully directly outward and the door literally pops off. starting from the bottom is a lot easier and there are a couple of grooves there where u can ge your fingers in. also, make sure not to pull too much, u need to disconnect the harness for your power windows/looks before you completely remove the pane. hope that helps...
-Joe
-Joe
This has been answered more than a few times. Please search before you post:
https://www.scionlife.com/forums/vie...hlight=speaker
McG_XB
22
Feb 10, 2004 09:53 AM
