Need Help!! Broke off bolt!! What the?
Old Jun 11, 2005 | 07:01 PM
bofa's Avatar
Default Need Help!! Broke off bolt!! What the?
I was putting my stock rims on my tC and was torquing the lugnuts and low and behold, the very last one.. :::pop::: And the f#ckin bolt broke off...
Anyone know how hard these are to replace and how much$??? Is this a simple DIY?
I can't believe this crap..
Old Jun 11, 2005 | 07:06 PM
bofa's Avatar
Oh yeah, and how safe is it to drive in the meantime?
Old Jun 11, 2005 | 07:13 PM
farberio's Avatar
If theactually bolt broke off....well...i think you need to replace the part behind the brake disk. So if your not all that familliar with brake work you might as well take it to the dealer.
I don't think its extremely all that unsafe to drive withought that bolt...you will just screw up your tire, and maybe your alignment, and possibly your wheel too. And it might also be possible to rattle that wheel so much to cause further damage.
I wouldn't drive withought that bolt...unless its just to the dealer to get it fixed but thats just me.
Boricua's Avatar
You're fine to drive on 4 lug nuts on a 5 bolt pattern. I'm yet to remove the wheels and the discs (brake, that is) so I have no idea how hard it is on these cars. If you have the right tools (read a good pulley) you should be able to do it quite easily on a car with disc brakes (so it won't matter if it's front or rear except for maybe the clearance).
A shop should be able to do for around $400, I imagine. It sucks 'cause the part is only like $10, LOL
Old Jun 11, 2005 | 09:30 PM
yaron_usa's Avatar
I wonder if you did anything wrong for it to do that... maybe the way the car was up (or down?). Could the part have been defective?
Old Jun 11, 2005 | 09:49 PM
Rivulent's Avatar
Were you using a breaker bar? Or was it just a < 1 ft wrench? If the latter, the bolt is defective for sure.
Old Jun 12, 2005 | 12:21 AM
bofa's Avatar
I was using a real torque wrench.. I hat eto say it's defective.. I've had my tC for almost a yeat and have 15K on it.
Well, I got it fixed. I called the dealership and the "stud" was about $3. I jacked it back up, took the wheel off, removed the calipers, and tapped the broken bolt through the other side.
Getting the new bolt in was a bit of a pain because of the dust shield, but I bent it a little and managed to get the new stud in.
Hammered it in, put the wheels back on a torqued it and I'm all set.
Old Jun 12, 2005 | 12:39 AM
doctorcue's Avatar
Nice fix! Glad to hear it didn't set you back hundreds!!!
Old Jun 12, 2005 | 11:28 AM
808tC's Avatar
your very lucky
Old Jun 12, 2005 | 08:22 PM
reagulator's Avatar
whoa i just broke my wheel stud yesterday too! how wierd is that. I was installing my injen cai. a local shop fixed it for me for 30 dollars
Old Jun 19, 2005 | 10:32 PM
johncal's Avatar
If you want to avoid breaking studs in the future either use an air gun or a cross shaped lug wrench. The problem with REMOVING bolts with a torque wrench or single lug wrench tire iron is the uneven side pressure exerted on the studs......el-snappo. Usually the lug nuts sieze up to some extent normally, requiring 100-150 pounds of torque to remove them at times.
Using the torque wrench or normal iron for re-installing is O.K. 'cause you're using less torque.
Also, the side benefit of using a torque wrench is that keeping even pressure on your wheels and rotors WILL actually help to keep the rotors from warping, usually........ not always however.
Old Jun 19, 2005 | 11:29 PM
hahaitzskippy's Avatar
did you torque the lugs down to much?!.
studs break also if they were loose and driven on...
i woud know... trust me
Old Jun 20, 2005 | 04:22 AM
jlaznlover's Avatar
good to see that you got it fixed. what i would have done was just put the stud in and use a bunch of washers and a lug nut. tighten the lug nut until it pulls the stud through. worked for me. much faster and easier than trying to hammer it in
Old Jun 20, 2005 | 04:25 AM
SPNFEDEJ's Avatar
u need to get a new wheel stud and have it push in
Old Aug 24, 2005 | 06:47 PM
Dat_Dude's Avatar
need to hammer in a new stud
Old Aug 24, 2005 | 07:02 PM
reagulator's Avatar
can we lock this? Revival of dead thread
Old Aug 24, 2005 | 07:43 PM
TheScionicMan's Avatar
Tech article here for replacing wheel studs:
https://www.scionlife.com/forums/viewtopic.php?t=26704
Locked.
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
crimson_sinn
Sep 25, 2015 09:41 PM
SCGBox
Sep 23, 2015 03:29 PM
