odd parking light flash sequence
Old Jan 17, 2009 | 02:08 AM
graphite06's Avatar
Default odd parking light flash sequence
it was -20 degrees thursday night in the chicago area. I went to start my car to let her warm up and pressed unlock once. it did what it normally does and flashed twice. i then pressed unlock a 2nd time and it did a half flash. i was like wtf? so i locked it and tried again, and again, and again: each time it did 2.5 flashes?
anyone know what this means?
Old Jan 17, 2009 | 04:18 AM
BZinn1's Avatar
Your car is angry you are taking her out in tothe cold......... .......nah I have no idea...flasher is probably jsut cold and not closing the relay properly....try it when it is warm.
Old Jan 17, 2009 | 04:52 AM
Agent99's Avatar
Might be a cold battery issue.
Old Jan 17, 2009 | 09:18 AM
sciontc_mich's Avatar
okay not to be a poop.. but do you operate properly when your body is -20 degrees? nope, neither does your car.
Not to say it's acceptable, but wait til it gets to a SANE TEMPERATURE to see if works normally.
Old Jan 17, 2009 | 03:23 PM
BZinn1's Avatar
it is the relay for the blinker/flasher not closing properly.when it is that cold the dielectric grease in it to lube it is so cold the switch is not moving properly.that relay is most likely under the dash,so drive a around and let car get warm in side and such and then lock and unlock and see if that solves it.
Old Jan 17, 2009 | 03:34 PM
SW_08's Avatar
i had the same problem last night and my car didnt wanna lock either
Old Jan 17, 2009 | 04:17 PM
BZinn1's Avatar
I am so glad it doesn't get that cold here.......sounds miserable.
Old Jan 17, 2009 | 07:54 PM
SW_08's Avatar
it is miserable.....
Old Jan 17, 2009 | 09:41 PM
graphite06's Avatar
that was my guess. after i got home everything worked fine. it did it again last night even though it wasnt quite as cold. oh well. thx guys
Old Jan 17, 2009 | 09:46 PM
kileil's Avatar
at least there's one good thing about when it's in the negative teens...
You can play the "lick your g/fs face and stick her to a sign post" game
Old Jan 18, 2009 | 04:43 PM
SW_08's Avatar
hahahahaha
YooItsJay
Dec 2, 2015 08:13 AM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
carid
Jan 8, 2015 11:33 AM
bruceb25
Nov 23, 2014 04:52 AM
hatchbox
Oct 3, 2003 03:41 AM
