Q about tire pressure monitor system
Old Nov 29, 2004 | 05:49 PM
SirWompus's Avatar
Default Q about tire pressure monitor system
from the FAQ:
- The tire pressure monitor system measures wheel speed at each wheel, and uses the outside ambient temperature to compensate correction for density. if a tire's pressure is low, you will be notified by a signal in the instrument cluster.
Interesting, so this is to say that it monitors the tire pressure without a actuall pressure sensor? What if you had one tire that was very worn [and thereby slightly smaller]. Would the system say that tire was low on air since it was rotating slightly faster then the rest of the tires?
Old Nov 29, 2004 | 06:11 PM
iridium_red's Avatar
Does the pressure monitoring system warm you if the pressure is more than the normal amount?
Old Nov 29, 2004 | 06:34 PM
zoltiz's Avatar
N.G.S.O.
Looks like TPMS only detects drastic changes in pressure of one wheel. With recent temperature drop I checked tire pressures and on of the front wheels was at 22psi, others were at 24-26-28. TPMS did not go off, probably because of the gradual pressure drop. So it makes sense not to trust the system completely. Keep a tire gauge handy.
Old Nov 29, 2004 | 06:40 PM
jlaznlover's Avatar
3 of my tires are slightly worn and one of them is brand new, so the tire light is always on for me now(even if i turn it off it comes back on i like 10mins of driving)
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
GoodVibes
Scion xB 2nd-Gen Wheel & Tire
Mar 3, 2015 09:47 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
