TC halo Headlights & Fog help
Hi, a week ago I purchase Ebay Halo head lights off of ebay also fog lights. I install both of the devices. I install the LED halo headlight and Led headlight to the parking light wiring. I manage to do this because I found a YouTube video of the company call spyder. They showed a step by step in how to do it. I test out the lights everything working good Except the Running day lights...I figure maybe a fuse or bad light bulb? So I left that alone and continue the project.
Next I started on the fog lights look easy enough to install...it came with a LED on and off switch. I connected all the components,grounded the black wire to the chassi. I figure the black was negative. Red positive. White I'm assuming it was power also for the LED light switch to turn on or off the fog lights? I connected the fog lights headlights to the parking lights. I tested the fog lights after I installed them. I press the LED on and off switch and everything was working. What happen next was I didn't like the On and off switch that came with it. I went to radio shack and bought a new toggle switch. Bigger easy to flip on and off also LED light on it. I cut the original on/off switch and replace it with the new switch. Now none of the LED lights halo included doesn't work and fog lights not working...I dont have a multimeter so what I did is that there is a connector that connects the fog lights wires to the original on/off switch. There are 3 wires black,red, and gray. I cut the connector and ran the power wire straight to the positive to the battery. The other wires I ran and mount to the new on/off switch and it work, but when I turn the **** to turn on the headlights the halo and led lights don't turn on...but when I flip the on/off switch the fog lights and the halo & LED lights turn on. My goal was to only have the fog lights turn on when I flip the switch on and to only have the little led light on the on/off switch turn on. I wanted the halo lights and the small LED lights to turn on when I used the car **** to turn on the main headlights like it is suppose to be. I will post pictures to try and be as detail as I can when I get off work on my lunch break. I will appreciate and feedback. Oh yes, also if anyone could help me with the running lights...I can't get it to work... Thank you.
sabot7726
Apr 28, 2016 08:20 AM
mischman
Sep 15, 2015 03:38 PM
umnitza
Jul 25, 2015 07:54 PM
