tC shakes when pushing/releasing the gas pedal. Please help!
hmm sounds like it's not a misfiring issue. I wonder if could be motor mounts are worn out for some reason and it is just the motor jerking. Or a vacuum issue. I would take it to the dealer since it is under warranty.
To build on my above thought, have you installed a new intake or exhaust lately? I'm thinking a dirtied/broken MAF or IAT sensor might screw up the car's logic enough to make it flutter the throttle, or maybe even exhaust o2 sensors if this car has 'em.
this is normal for a tc. mine and my sisters (hers is auto, mine is stick) do this. the answer is above. its a combo of the engine mounts and the drive be wire. its the engine rocking back and fourth
solution:
1) live with it
2) clutch it a little when letting off gas
3) new engine mounts
4) engine torque dampener
your car is fine, if there was a major problem it would throw on a cel. i have this problem too but its no biggie!
solution:
1) live with it
Originally Posted by talagang_crazy
i installed a CAI last june, and exhaust was early january. i checked my MAF and it was perfectly clean,.
So I went to get it checked out and it turned out to be the tires...
apparently my tires are harder material which causes the car to shake a little but with a little balancing, the shaking goes away...
Originally Posted by Nu-Nu
I've had the car nearing 3 years. It is manual, and the issue occurs when I'm already clutched out, and I am just pushing/releasing the gas pedal.
This maybe be related to the drive by system itself since it controls how much throttle to use, no?
BlingSlade
11-20-2015 06:56 PM
Klashan
09-24-2015 12:39 PM
