2007 tC Rear Backing Plate..
Old May 12, 2020 | 10:47 PM
richet's Avatar
Default 2007 tC Rear Backing Plate..
Had a lot of trouble getting rotor off because of brake shoe hanging up. Ended up the shoe was no longer being held in place by the pin and spring clip because that part of the plate rotted away.
I know I could fashion my own to hold the shoe in place or just remove the shoes altogether and not have a parking brake in one wheel. I would rather fix it right but there seems to be little info on buying and replacing a new one.
It is the rear passenger side. Is removing the wheel hub needed?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; May 12, 2020 at 10:54 PM. Reason: Moved to Correct Forum by Administrator
Old May 13, 2020 | 04:11 AM
JakeAut0's Avatar
I would say that you will most likely have to remove the wheel hub.
You can use this to look up part diagrams if it helps (https://partsouq.com/)
Old May 14, 2020 | 01:26 AM
62Fender's Avatar
Cool website, JakeAut0.
Plate Sub Assembly, Right side - 4650321010
This ain't necessarily the best price, it's just the first search return on the part number. There are many more.
https://www.toyotapartsdeal.com/oem/...503-21010.html
If that's more cash than you're looking to spend, you might find a decent plate at a salvage yard.
Old May 15, 2020 | 10:21 AM
richet's Avatar
sorry for the delay alot of other things popping up at the same time. thanks for the response. the cheapest online dealer price was 145 but i found two 06's at the local pick and pull about 40 minutes from me and according to their price list is 17 dollars. northeast rust. gotta love it.
Old May 15, 2020 | 10:32 AM
richet's Avatar
i would also like to say that is a great website. incredible detail. thank you.
Old May 15, 2020 | 11:43 AM
62Fender's Avatar
Glad you found a used one. ~$150 for a new one is too expensive.
Old May 15, 2020 | 10:14 PM
JakeAut0's Avatar
Pick n pulls are always a great place to find decent parts for cheap, glad you found one.
jonb2
Oct 17, 2017 08:39 PM
62Fender
Apr 6, 2017 06:03 PM
Joeynenj
Dec 4, 2010 02:32 PM
cheXmiXB
May 25, 2009 08:06 AM
ROBs-xB
Jan 25, 2009 09:33 PM
