after installed front s tein spring
after i installed s tein front spring with stock shock the front driver side brake started to make a click noise. when i put the car in reverse then press the brake and release it you can hear the click sound from the driver side brake.this only happen when you put it in reverse and press on the brake. overall i like drop.i'm going to drop the rear tomorrow. then i'll post pictures later when i have the time.thanks for the reply.
Bet your car is sitting pretty...
Anyway, have you checked all the lines that are around the shock to make sure they aren't bound up or anything? Not really sure that is the culprit, but I would at least pull the wheels off and check everthing...
kleecker
Jan 9, 2015 02:26 PM
TheTripleC
Jan 4, 2015 06:46 PM
fluxingnation
Dec 26, 2014 04:28 PM
