alignment at dealer?
well im on s techs and i haven't gotten an alignment yet and was wondering if my dealer would "accept" my tC since it's lowered on a non-toyota/trd suspensionpart.. i was always curious about that.. will i be able to bring it in even lowered on s-techs?
dealers can also work like regular maintanence shops, just don't tell them about the springs, just that you want to do an alignment. you figure they can't just deny you business and it's not like it's any warranty work. either way they can't void the warranty
I dont think it should matter anyway. all they do is hook up these pads to you rims that are read by lasers. if the tire is uneven or not straight, then the computer will read it and let them know how much to starighten it. my friend works at a dealer. he does ALOT of lowered cars.
sIcKsCiOnS
DelMarVa
Scion Tuners
now, it may be slightly difficult to get your car on the lift, since your sitting low
i kno mine was a butt when i had my s-techs, had to use boards to get it on the lift
ic.. I recently got this letter from my dealer saying I have this scheduled "Maintenance" appointment... exactly what do they do with this service? I have an unbolted exhaust, should I bolt it back in before I give it up for service?
No. see the only way that they'll actually void any warranty for anything on your car is if lets say your car is leaking gas and you have some aftermarket fuelrails that might contribute to the cause as of why its leaking, then they will void it. but for small mods like exhausts or cold air intake systems they wont.
sIcKsCiOnS
DelMarVa
Scion Tuners
but they should have no issue working on your car with unbolted exhaust
You're asking about warranty issues after you modded your car? Shouldn't it be the other way around?
Anyways, I had no problem taking my lowered tC[rap] to a dealer and them aligning. They even re-aligned it for free after a month later when I noticed it was pulling to the left.
sIcKsCiOnS
DelMarVa
Scion Tuners
As a tech who works for a dealership I can tell you any dealer can align your car. However they may have trouble with getting it on the rack. In which case they can deny to work on it, however this is very unlikely. Also you may actually have to pay more for your alignment due to the excessive negative camber issue. Not all dealers do this but some do. I did my alignment myself on tein s-techs and have had no issues. My shop is not setup for lowered cars so it took alittle finessing. One nice thing is these cars do have a rear camber adjustment from the factory, however there is not enough front factory adjustment. You will need to purchase some sort of camber kit. My personal suggestion is upper pillowball mounts. The eccentric bolts will work however it is a very long process as the technically don't have enough adjustment. It took about 2 and a half hours for me to do my alignment and I do them every day. As for the warranty issue. There is no such thing as "voiding" your warranty. However if your car has an issue and a dealer can prove that your tampering or modifying caused that specific issue then they can deny you warranty coverage. Example your lowering springs on stock struts and then the struts get blown out, will not not be covered. Hope this helped.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
