alignment questions
im going for an alignment tomorrow an i need to know what to tell the tech to set my toe at..im sick of chewing 800$ tires up in less then a year.i was just going to have them set it at 0 front 0 rear. does anyone have any suggestions?
Originally Posted by ack154
Any place you go should access to the specs for the tC... but just in case, here's what they are:
Front: +/- 0.10*
Rear: 0.05* to 0.25*
Front: +/- 0.10*
thanks man
The rear is all +... though a 0 wouldn't be too bad.
my car wonders really bad on the freeway..thank you very much
really any shop you goto has an alignment rack that aligns it all by computer placement of the sensors.as long as your not dropped on stechs and need a camber kit to bring it in specs you will be fine.it depends on how it was built at the factory really as to where your initail specs seem to be + or -........
Originally Posted by shoopajae
just take it like a man and pay the 800. you know you're ballin.
i have energy suspensions control arm bushings front and rear and all 4 rear subframe mounts so all the factory settings will be crap as they are ment to play off the factory suspensions slop.
bootlgr
Jan 26, 2016 01:22 AM
