BC BR Coilovers knocking/clunking issues???
Old Dec 23, 2013 | 05:00 PM
xdejablu3x's Avatar
Question BC BR Coilovers knocking/clunking issues???
Anyone having this issue with these coilovers? Recently mine started doing that it could either be a broken shock cartridge or something is loose and not tightened down. It's pretty annoying and very present when the back wheels drive over bumps or uneven pavement. Sometimes when your doing fast turns as well.
Old Jan 7, 2014 | 12:25 AM
DigitalPro's Avatar
Are you sure it's the coils? What swaybar are you running?
Old Jan 12, 2014 | 03:03 AM
xdejablu3x's Avatar
I finally located the problem. I thought it was the coilovers but it turns out that the nut holding the steel bolt for my sway bar busted and stripped. This caused it to be loose and the bolt knocking around. Hopefully my coilovers will be good in the long run though because the Scooby guys do run into problem more often than most think with these.
anthonyTC2
May 18, 2015 12:04 AM
pro5man
Scion xB 2nd-Gen Wheel & Tire
Mar 4, 2015 12:38 AM
TheTripleC
Jan 4, 2015 06:46 PM
fluxingnation
Dec 26, 2014 04:28 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
