Best place other then the dealer to get alignment...........
Old Jan 22, 2008 | 11:24 PM
TinmanTC's Avatar
Default Best place other then the dealer to get alignment...........
after a lowering spring install?
Looking for a reputable/quality place that can get the job done.
I'm going to be TRD springs.....do I tell the tech anything special? Or just walk in and say I need an alignment?
Where did you guys go?
Old Jan 22, 2008 | 11:52 PM
Yanki01's Avatar
local allignment shops, yellow book? i would also wait about 2 weeks before you get one, let the springs settle.
Old Jan 22, 2008 | 11:58 PM
TinmanTC's Avatar
Right...Is there a difference?
Good year, midas, firestone etc......
Are some alignment machines more advanced then others? Or are they all the same?
Just want to make sure I get a good alignment with the most current alignment systems?
Old Jan 23, 2008 | 12:46 AM
bigwillystyle23's Avatar
sears auto center is pretty good. 70 dollars for an alignment but its a good alignment system. also, the alignment carries a 6000 mile/6month warranty.
go get the alignment right after you drop it and then go get another one after your springs settle. your tires will thank you!
Old Jan 23, 2008 | 12:52 AM
TinmanTC's Avatar
Im just going to abrely drive the car for a few weeks till they settle then get the alignment.
I will keep sears in mind, thanks!
Old Jan 23, 2008 | 12:55 AM
the 2nd alignment is absolutley free because of that warranty.
Old Jan 23, 2008 | 02:58 AM
BuddhasTC's Avatar
check out bear allignment in glendora, it's about 30 minutes away from u in apple valley...if ur cars too low, they might be one of the few places that can do it because the shop needs a pit lift...not the standard one most places have
Old Jan 23, 2008 | 07:02 AM
xilver's Avatar
firestone's lifetime alignment for $170
Old Jan 23, 2008 | 07:07 AM
CRUZtc8's Avatar
any local discounttire
Old Jan 30, 2008 | 10:47 PM
TinmanTC's Avatar
Getting my springs installed saturday.
Waiting 3 weeks for alignment...
I have heard horror stories about firestone, what's everyone's experiences here?
Old Jan 30, 2008 | 11:23 PM
WendysOrBust's Avatar
Are you really planning on waiting 3 weeks for you alignment? With our type of rear suspension whenever we lower our cars we also add rear Toe to the car. And added toe will wear out your tires like no other. I'd suggest getting it done the following day if not the same day..
As far as alignment places go they're all pretty much the same, its not rocket science adjusting the camber, on the fronts you just turn the upper bolt on the bottom of the shock. While on the rears to adjust the upper arm. Depending on the springs you might need the aftermarket camber bolts and adjustable rear camber arms.
Old Jan 31, 2008 | 12:03 AM
BuddhasTC's Avatar
3 weeks is fine...i had mine lowered for nearly 3 months be4 i got mine and my tires still lasted me another year after that...it takes a while for the wear and tear to take a toll...especially with a minimal drop as the TRD
Old Jan 31, 2008 | 02:11 AM
TinmanTC's Avatar
Yep, going to wait 3 weeks, unless I get some type of "lifetime alignment" deal. Which is about $200.
I plan on riding my street bike more often during those 3 weeks so I do not put many miles on the car while the springs are settling.
Arent there a few different types of alignment? 3d, computer etc etc.
I'm also wondering if I have to let them know i that I have TRD springs, or does it not matter?
I think they measure the ride height, or at least they are supposed to do.
Old Jan 31, 2008 | 02:23 AM
tCeeder's Avatar
the break in/settling period for the springs goes much faster if you actually drive the car around town like normal, but aggresively.
Old Jan 31, 2008 | 02:31 AM
TinmanTC's Avatar
hmm, I guess I will have to find the right balance between driving the car, and letting them settle.
I dont want to put too many miles on without alignment!
Old Jan 31, 2008 | 02:37 AM
tCeeder's Avatar
i know what you mean, my tc = my work vehicle so i didnt want to go too crazy, but i wasnt about to leave it in the driveway for a couple weeks. might as well help the car get used to the springs and the springs used to the weight so that you only need one alignment.
Old Jan 31, 2008 | 05:34 PM
davedavetC's Avatar
lol i went a full year and a half after dropping on hotchkis which is a lot lower then TRD before i got an alignment. i went through the stock tires, then got NeoGens because they are designed for negative camber. no problems, just drive the damn thing
Old Jan 31, 2008 | 05:42 PM
tCkid2005's Avatar
firestone?
they do lifetime allignments and i got mine there
Old Jan 31, 2008 | 07:35 PM
TinmanTC's Avatar
Originally Posted by tCkid2005
firestone?
I know every firestone is different, but are you happy with the service?
Old Jan 31, 2008 | 08:34 PM
yellowxhoodie's Avatar
im dropped on S-Techs and have nvr been aligned.
no noticable camber or anything.
drop it first, then see if its really necesarry.
