brake rotors
Old Jun 19, 2008 | 12:37 AM
coldbloodedtc's Avatar
Default brake rotors
ok ive searched and i havent really found a whole lot.
im in hte market for upgrading my rotors and pads. My pads are starting to make some noises and i might as well upgrade my rotors while im at it since i plan to *hopefully* turbo sometime.
My question is whats better drilled, slotted or both?? Ive looked into powerslot, StopTech, and dezods rotors that they market.
Any suggestions and if u could provide info that would be great
Old Jun 19, 2008 | 12:44 AM
2_much_tc's Avatar
http://store.r1concepts.com/Store/Se...=1&key=av13623
Old Jun 19, 2008 | 01:19 AM
ok that was a great help thanks alot
Old Jun 19, 2008 | 03:54 AM
Spicy_McHaggiz's Avatar
In theory drilled and slotted rotors are great, however on a car like ours they'd rarely get the use in which they were designed. (unless doing auto-x, hpde, etc etc)
However if you want the look of a performance brake system, go slotted. Drilled rotors have a cracking problem (almost every brand at some point) when used extensively. No matter what a slotted/drilled rotor will eat through brake pads faster then non drilled or slotted.
Old Jun 19, 2008 | 04:00 AM
scion_jon's Avatar
i just got these monday, slotted too, never go drilled, or you can try dimpled
Old Jun 19, 2008 | 12:56 PM
scion_jon where did u order all that from just curious. Most of the high end cars use drilled rotors... i see g35's with them all the time.
Old Jun 19, 2008 | 07:08 PM
scion_jon's Avatar
i ordered from trdsparks.com
Old Jun 19, 2008 | 08:42 PM
enjoithis's Avatar
www.customizemyscion.com has the stoptech kits in stock. drilled, slotted, and both
Old Jun 19, 2008 | 08:47 PM
2_much_tc's Avatar
^ the link doesn't work.
Old Jun 19, 2008 | 09:33 PM
paul_dezod's Avatar
Scionetics
KAD
We can get all of your StopTech needs nailed down VERY quickly. We are a direct WD.
http://www.dezod.com/cat_staged.cfm
dougcbx
Oct 23, 2015 11:42 PM
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
